Old 24-02-2019, 08:51   #1411
Radioeng
Noted at 08.45 UTC on Sunday 24th February already broadcasting reports on the Nigerian election. 17dB SNR, usual mode C with 9.1 kbps codec in English.
Radioeng is offline   Reply With Quote
Old 25-02-2019, 07:21   #1412
Frequency: +
Codec: -
Modulation:+
With the current azimuth, very little reception here, but I'll continue to monitor.
Old 28-02-2019, 17:04   #1413
marsel90
marsel90's Avatar
https://www.youtube.com/watch?v=A-C4...ature=youtu.be
marsel90 is offline   Reply With Quote
Old 14-03-2019, 11:25   #1414
Good signal, poor audio:
Old 14-03-2019, 12:05   #1415
With the Voice Of Nigeria and DRM_radio_kuwait side by side at the same time and fieldstrength I took some comparing screenshots:
Old 14-03-2019, 20:54   #1416
Your good reception of Voice of Nigeria in Europe and Philip's reception in eastern NA are just another reason why WINB should NOT be using 15120 kHz at the same time as VoN during the forthcoming season.
Old 14-03-2019, 22:44   #1417
Strong signal, terrible audio quality:
Old 16-03-2019, 17:18   #1418
Frequency: +
Codec: -
Modulation: +
Old 21-03-2019, 20:03   #1419
Good signal with one TX dropout, bad audio:
Old 22-03-2019, 19:54   #1420
Frequency: +
Codec: -
Modulation: +
Signal was extraordinarily weak, but it was there ... even on the outdoor antenna. With the wind, I didn't dare use my magnetic loop outside on a stand ... The summarized results were obviously spurious. As long as VoN broadcasts only during this time, I don't have a problem with WINB broadcasting on this same frequency until 1700Z.
Old 23-03-2019, 17:41   #1421
March_23
Weak signal, just over ~32dBuV. 99.56% CDA / 22.4dB max SNR.
Old 23-03-2019, 20:55   #1422
Stable reception here with insufficient audio quality:
Old 24-03-2019, 06:05   #1423
dxing.org
Last night (23.03.2019) Radio Voice of Nigeria received in Sofia, Bulgaria:
https://youtu.be/oBTPWCU1WhM
dxing.org is offline   Reply With Quote
Old 25-03-2019, 19:50   #1424
Frequency: +
Codec: -
Modulation: +
Brief audio wasn't bad... The poor quality of VoN's remote feeds is the main problem although a boost in the bit-rate for 16 QAM by switching to Mode B is certainly appropriate.
Old 27-03-2019, 01:15   #1425
Frequency: +
Codec: -
Modulation: +
