Thread Tools | Search this Thread | Display Modes |
#1 |
CVC is pleased to announce a period of regular daily transmissions in Portuguese from Santiago targeting Brazil.
Time: 1900-1200 UTC Frequency: 17645kHz Power: 15kW Broadcaster: Voz Crista Language: Portuguese Bearing: 45 deg Target: Brazil DRM technical parameters will vary Reports and comments welcome here as always Many thanks Andrew Flynn |
#2 |
Location: Karlsruhe (Germany) and Boulogne-Billancourt (France)
Hi Andrew,
if you don't get any report from Brazil, at least a "poor" report from Europe. Very weak signal detectable from 19h24 to 19h37. However no station name in Dream :-( and far away from any audio. 73 Daniel |
#3 |
CVC - Chili
Time : 19h45 UTC
Location : Curitiba / PR - Brasil Receiver : DWT Antenna : dipole Freq : 17645 KHz SNR : 10,0 dB Audio : 50 % (better at the end) AAC mono 11,6 kps Denis |
#4 |
29/01/2006
No transmission on 17645 Khz. Denis Curitiba |
#5 |
31/01/2006
Time : 19h50 UTC Location : Curitiba / PR - Brasil Receiver : DWT Antenna : dipole Freq : 17645 KHz SNR : 13,0 dB Audio : 595 % AAC mono 11,6 kps Denis |
#6 |
At least personal record distance so far
No sound but at least a trace of DRM over quite a distance. 73 Terje |
#7 |
Thank you for your responses so far.
Denis: Please can you confirm: was the audio yesterday 95% or 59%? Thank you for the feedback - this is very useful! James |
#8 |
audio was 95 % (from 19h40 UTC to 20h00 UTC).
Today, will try to listen from 19h00 UTC up to the end. Denis |
#9 |
01/02/2006
Time : UTC 19h02 - SNR: 7.9 - aUDIO : 0% 19H05 - SNR: 7.3 Location : Curitiba / PR - Brasil Receiver : DWT Antenna : dipole Freq : 17645 KHz Audio : 595 % AAC mono 11,6 kps Denis |
#10 |
01/02/2006
Time : UTC 19H02 - SNR: 7.9 - AUDIO 0% 19H05 - SNR: 7.3 - AUDIO 0% 19H10 - SNR: 7.0 - AUDIO 0% 19H15 - SNR: 7.9 - AUDIO 0% 19H20 - SNR: 5.5 - AUDIO 0% 19H25 - SNR: 7.7 - AUDIO 0% 19H30 - SNR: 5.5 - AUDIO 0% 19H35 - SNR: 7.3 - AUDIO 0% 19H40 - SNR: 10.5 - AUDIO 30% 19H45 - SNR: 11.4 - AUDIO 60% 19H50 - SNR: 11.7 - AUDIO 80% 19H55 - SNR: 13.1 - AUDIO 100 % 19h57 - SNR: 13.5 - AUDIO 100% 19H58 - END Location : Curitiba / PR - Brasil Receiver : DWT Antenna : dipole Freq : 17645 KHz AAC mono 11,6 kps TELEFUNKEN DMOD02 Notes : 1) Reception was better yesterday as from 19h40 up to the end I had a 95% audio. 2) Today audio comes only after 19h40, getting better and better up to the end of transmission. 3) Maybe you should delay one hour your test transmission for better propagation ? 4) Your analog signal on 15.485 kHz comes much stronger that the digital signal. A test on the 19m band ? Denis |
#11 |
1st February
Just for fun, one hour's monitoring from Switzerland. 73 Terje |
#12 |
The Sun did not cooperate today. Traces of DRM and 0-3 dB SNR. 73 Terje Last edited by Digger : 03-02-2006 at 06:12. |
#13 |
02/02/2006
Time : UTC 19H05 - SNR: 11.2 - AUDIO 95% 19H10 - SNR: 11.8 - AUDIO 100% 19H15 - SNR: 11.8 - AUDIO 100% 19H20 - SNR: 11.2 - AUDIO 95% 19H25 - SNR: 12.1 - AUDIO 100% 19H30 - SNR: 12.2 - AUDIO 100% 19H35 - SNR: 12.5 - AUDIO 100% 19H40 - SNR: 12.1 - AUDIO 100% 19H45 - SNR: 12.5 - AUDIO 100% 19H50 - SNR: 11.9 - AUDIO 100% 19H55 - SNR: 11.9 - AUDIO 100 % 19h58 - SNR: 12.3 - AUDIO 100% 19H59 - END Location : Curitiba / PR - Brasil Receiver : Yaesu FT817ND + Sat-Schneider Mixer 455kHz/12kHz + software DRM (The DWT receiver gives me a SNR 4.7 lower that the Yaesu FT817ND.) Antenna : dipole Freq : 17645 KHz AAC mono 11,6 kps Denis |
#14 |
03/02/2006
Time : UTC 19H05 - SNR: 11.0 - AUDIO 90% 19H10 - SNR: 11.1 - AUDIO 90% 19H15 - SNR: 10.2 - AUDIO 80% 19H20 - SNR: 11.0 - AUDIO 90% 19H25 - SNR: 11.1 - AUDIO 90% 19H30 - SNR: 11.1 - AUDIO 90% 19H35 - SNR: 11.2 - AUDIO 90% 19H40 - SNR: 11.3 - AUDIO 90% 19H45 - SNR: 11.2 - AUDIO 90% 19H50 - SNR: 11.1 - AUDIO 90% 19H55 - SNR: 11.1 - AUDIO 90 % 19h58 - SNR: 11.3 - AUDIO 90% 19H59 - END Lots of static noise today. Location : Curitiba / PR - Brasil Receiver : Yaesu FT817ND + Sat-Schneider Mixer 455kHz/12kHz + software DRM Antenna : dipole Freq : 17645 KHz AAC mono 11,6 kps Denis |
#15 |
07/02/2006
Time : UTC 19H50 - SNR: 12.3 - AUDIO 100% 19H55 - SNR: 12,6 - AUDIO 100 % 19h58 - SNR: 12,5- AUDIO 100% 19H59 - END Location : Curitiba / PR - Brasil Receiver : Yaesu FT817ND + Sat-Schneider Mixer 455kHz/12kHz + software DRM Antenna : dipole Freq : 17645 KHz AAC mono 11,6 kps Denis |
| Display Modes | |
