Old 20-11-2016, 05:20   #16
19 Nov 2016 : RRI on 9770 kHz from Galbeni
99% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 0. Local K-index: 0.
Planetary A-index: 3. Solar flux: 78. SWPC Sunspot number: 28.
Sunrise 07:29 UTC.
Old 20-11-2016, 19:09   #17
20 Nov 2016 : RRI on 9770 kHz from Galbeni
03:00-06:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 3. Solar flux: 78. SWPC Sunspot number: 22.
Sunrise 07:30 UTC.
Old 22-11-2016, 05:14   #18
21 Nov 2016 : RRI on 9770 kHz from Galbeni
98% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 1. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 4. Solar flux: 76. SWPC Sunspot number: 11.
Sunrise 07:32 UTC.
Old 23-11-2016, 05:36   #19
22 Nov 2016 : RRI on 9770 kHz from Galbeni
03:00-06:00 UTC Planetary K-index: 1-. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 1. Local K-index: 1.
Planetary A-index: 6. Solar flux: 75. SWPC Sunspot number: No data available.
Sunrise 07:34 UTC.
Old 24-11-2016, 05:18   #20
23 Nov 2016 : RRI on 9770 kHz from Galbeni
03:00-06:00 UTC Planetary K-index: 3-. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 3. Local K-index: 2.
Planetary A-index: 12. Solar flux: 77. SWPC Sunspot number: No data available.
Sunrise 07:35 UTC.
Old 24-11-2016, 17:45   #21
24 Nov 2016 : RRI on 9770 kHz from Galbeni
06:00-09:00 UTC Planetary K-index: 3-. Local K-index: 2.
Planetary A-index: 13. Solar flux: 78. SWPC Sunspot number: 11.
Sunrise 07:37 UTC.
Old 25-11-2016, 19:19   #22
25 Nov 2016 : RRI on 9770 kHz from Galbeni
03:00-06:00 UTC Planetary K-index: 6-. Local K-index: 5.
06:00-09:00 UTC Planetary K-index: 5+. Local K-index: 4.
Planetary A-index: 24. Solar flux: 79. SWPC Sunspot number: 12.
Sunrise 07:38 UTC.
Old 27-11-2016, 05:45   #23
26 Nov 2016 : RRI on 9770 kHz from Galbeni
92% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 2. Local K-index: 2.
Planetary A-index: 32. Solar flux: 81. SWPC Sunspot number: 12.
Sunrise 07:40 UTC.
Old 28-11-2016, 05:21   #24
27 Nov 2016 : RRI on 9770 kHz from Galbeni
97% decoded audio during the transmission.
Planetary A-index: 12. Solar flux: 81. SWPC Sunspot number: 13.
Sunrise 07:41 UTC.
Old 28-11-2016, 06:32   #25
Log from NZ for November 28th
Old 28-11-2016, 19:42   #26
28 Nov 2016 : RRI on 9770 kHz from Galbeni
03:00-06:00 UTC Planetary K-index: 2-. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 2-. Local K-index: 1.
Planetary A-index: 10. Solar flux: 82. SWPC Sunspot number: 31.
Sunrise 07:43 UTC.
Old 30-11-2016, 05:41   #27
29 Nov 2016 : RRI on 9770 kHz from Galbeni
95% decoded audio during the transmission.
Planetary A-index: 8. Solar flux: 85. SWPC Sunspot number: 44.
Sunrise 07:44 UTC.
Old 30-11-2016, 06:40   #28
30 Nov 2016: RRI on 9770 kHz from Galbeni
RRI GALBENI with a weak signal. There was never enough signal to see a Label.
At 0634 UTC there was a TX failure that lasted about half a minute. I hope to get this verified by Neil. At 0654 UTC I made a screenshot of the waterfall in DReaM.
Then I put a log in the wrong thread: Galbeni, not Tiganesti, was logged for 14 minutes from 0641 UTC on the 28th November. No Label, 7.48 dB max. SNR and no decoded audio. See the second attachment.
Old 30-11-2016, 19:05   #29
30 Nov 2016 : RRI on 9770 kHz from Galbeni
90% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 1. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 1-. Local K-index: 0.
Planetary A-index: 5. Solar flux: 85. SWPC Sunspot number: 43.
Sunrise 07:46 UTC.
Terje, there was a break in the DRM signal at 06:34 UTC, but looking at the signal strength plotted, there was still a carrier.
Old 02-12-2016, 05:22   #30
1 Dec 2016 : RRI on 9770 kHz from Galbeni
03:00-06:00 UTC Planetary K-index: 1+. Local K-index: 1.
Planetary A-index: 3. Solar flux: 84. SWPC Sunspot number: 75.
Sunrise 07:47 UTC.
