Old 04-09-2010, 21:06   #1096
Best log for a long time. I did something which caused a dropout at 1904 UTC. Max SNR here: 24.9 dB
Old 04-09-2010, 21:27   #1097
stef
stef's Avatar
Originally Posted by FritzWue
Hi Stef, must have been a local problem. Good signal tonight, also one dip here.
Attached are two panadapter screenshots at the same signalstrength with low and high intermodulation giving 24 dB and 16 dB SNR.
strange ,you have a strong signal also 9+ i have 5-7 always weak maybe my dipole is not in the good direction.
stef is offline   Reply With Quote
Old 05-09-2010, 14:33   #1098
Sept. 04
That's the results last night. Weak and unstable signal but SNR reached 23 dB.
Old 05-09-2010, 20:08   #1099
audio only at the end.
Old 05-09-2010, 20:09   #1100
stef
stef's Avatar
Bad log bad decoding
Old 06-09-2010, 07:38   #1101
5th Sep.
No audio at the very beginning, but after a TX re-start everything worked OK. The signal was very weak between 1826-1904 UTC with only 36% decoded audio in that segment. The overall result was around 78% decoded audio.
Old 06-09-2010, 20:04   #1102
5th September 2010
Strange signal at beginning, first low snr with intermodulation and no audio,
then lower intermodulation and better snr with audio.
Later there was a carrier fastly scanning the band from low to high several times making the snr plot look as if there was lightning.
I tried to catch it on a screenshot but it was too fast.
Old 06-09-2010, 20:07   #1103
Good signal tonight:
Old 06-09-2010, 20:07   #1104
stef
stef's Avatar
Good log today with a dip between 18u20-18u37,and after that high snr +20.
Old 06-09-2010, 20:35   #1105
Telspace
Today's log
Telspace is offline   Reply With Quote
Old 06-09-2010, 20:56   #1106
I was a few minutes late this evening. A fairly good log; not as good as FritzWue's, but better that Telspace's. The SNR peaked at >25 dB just before the end of the log. The SNR is directly related to the signal strength.
Old 07-09-2010, 20:09   #1107
stef
stef's Avatar
A hard start then good,a big dip from 18u44 until 18u58 and the last 3 hours good.
Old 07-09-2010, 20:22   #1108
Signal improved from 1840, but I could not log three hours in Switzerland...
Old 07-09-2010, 21:00   #1109
Telspace
As usual....Don't know what to do to improve this.
Old 07-09-2010, 21:18   #1110
Propagation was not that good tonight, very wide impulse response with lower snr:
