Old 06-06-2010, 21:18   #931
June 06
A little better tonight.
Old 09-06-2010, 20:17   #932
June 09
When the path opened I got the attached log.
Old 10-06-2010, 08:08   #933
9th June
The conditions improved after 1920 UTC and got better and better during the last 40 minutes.
Old 10-06-2010, 20:09   #934
June 10
The signal got better around 18:55, at about 19:00 some break downs occurred, then the results turned good until the end.
Old 10-06-2010, 20:53   #935
A super short log, because I noticed strong Es over Rome, so I switched to 26 MHz instead.
Old 11-06-2010, 20:20   #936
June 11
The results tonight.
Old 11-06-2010, 20:58   #937
From 1902 UTC and on the reception was perfect.
Old 12-06-2010, 22:39   #938
PP5AZF-Ataliba
Propagação muito variável.
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 13-06-2010, 08:21   #939
stef
stef's Avatar
it seems that reception in europe is better than the target:brazil
stef is offline   Reply With Quote
Old 13-06-2010, 09:31   #940
12th June
The label was visible when I started the log, but the band opened around 19 UTC. The rest was almost perfect.
Old 13-06-2010, 21:27   #941
The band did not open up enough this evening...
Old 14-06-2010, 20:10   #942
June 14
The path opened very late.
Old 14-06-2010, 22:04   #943
It got gradually better from 1840 UTC, but the path opened around 30 minutes before the end of the transmission.
Old 15-06-2010, 20:36   #944
The band opened up much earlier tonight.
Noted a Mode Change at 1930. It did not improve the reception though...
Old 15-06-2010, 21:15   #945
PP5AZF-Ataliba
Propagação muito instável.
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
