Old 27-01-2014, 16:15   #1711
RNZI 9870 kHz reception near Atlanta, Georgia, USA
This morning's reception (last three hours) - 62.02% audio decoded.
AF4MP is online now   Reply With Quote
Old 28-01-2014, 14:05   #1712
This morning's reception (last three hours) - 75.59% audio decoded.
Old 28-01-2014, 16:37   #1713
A meager 36.66 % CDA today. Even the "best bit" was no good at all.
Old 29-01-2014, 04:05   #1714
Ambient Conditions: Unknown as I wasn't planning on posting this log. PC & M2 off, but lithium battery charger on ( 6 dB loss from 0910Z )
Within a week, we're headed for another round of frigid temperatures, i.e. WAY below 0 F. This condition in early February is common in the central USA as increasing sunlight begins to loosen frigid air masses in the arctic. I pity the folks living in the humid eastern and southern parts of the USA.
Old 29-01-2014, 14:09   #1715
Only the last hour produced some audio. With Doppler above 1 Hz there is a small chance to get any decoding.
Old 30-01-2014, 11:42   #1716
97.2% decoded audio (1st attachment) from 1016-1132 UTC. 67.56 % decoded audio (2nd attachment) for the whole log,
Old 31-01-2014, 11:53   #1717
The poor receiving conditions improved when I switched off the TV set at 1118 UTC.
Old 31-01-2014, 16:07   #1718
Originally Posted by AF4MP
Have you tried ferrite cores on the problem cable?
Yep, 8 ferrite clamps in a row on the satellite coax helped a lot, but only in stand-by. Need to rearrange the cables, unfortunately a tricky job...
Old 06-02-2014, 10:33   #1719
A brief log of just 5 minutes while the power to this part of the city was lost for nearly 3 hours with a temperature of -20 degrees F. The digital signal was marginal so I switched to the analog broadcast from RNZI on 9765 kHz. Naturally, the DR111 was running from my 18650 battery pack. Thankfully, we use natural gas for heating.
Old 07-02-2014, 16:08   #1720
Environmental Conditions: PC & M2 off ( 0 dB loss )
I won't rate this partial log.
Old 15-02-2014, 22:27   #1721
RNZI with DPRK splatter and Plasma TV local QRM. And AIR in AM on the same QRG seems to be a problem too here. Logged minutes from 0821-1157 UTC. 62.53% CDA.
Old 16-02-2014, 12:24   #1722
Logged from 0809 UTC. At that time heavy splatter from DPRK. Logged 228 minutes from 0809-1156 UTC. 36% CDA. Not very good compared to some years ago.
Old 18-02-2014, 11:22   #1723
9870 kHz, from 1007 UTC RNZI logged 1 h 51 min from 1007-1058. Max. 18.14 dB SNR and 90.08% decoded audio.
Old 19-02-2014, 22:50   #1724
logged RNZI 0910-1035 UTC but too much in-house plasma TV QRM. Only 16% decoded audio.
Old 20-02-2014, 23:18   #1725
20th Feb
RNZI logged from 1040-1158 UTC. 19.24 dB max. SNR and 92.18% decoded audio.
