Old 25-08-2005, 17:17   #1
Baldo34
Baldo34's Avatar
7465 kHz BBC WS from Kvitsoy
BBC WS now (17:15 UTC) on 7465 kHz from Kvitsoy, Norway.
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 25-08-2005, 19:25   #2
Andreas
Junior Member
Andreas's Avatar
and here are the results from..........
Not really bad I would say.
Andreas is offline   Reply With Quote
Old 25-08-2005, 19:49   #3
radiomann
radiomann's Avatar
first hour very good and still going strong now.
Paul
radiomann is offline   Reply With Quote
Old 25-08-2005, 20:18   #4
52°N 07°E
Finally ending up in the dead zone, but good results with good audio.
Friedrich.....DK6QI.....JO31mw
SDR is the meteor that kills dinosaur radios.
FritzWue is online now   Reply With Quote
Old 25-08-2005, 21:05   #5
Reception was not really good. But many dropouts occured only because Dream does not support UEP with the current versions of FAAD2.
Old 26-08-2005, 04:20   #6
bad results using the DWT, no interferences, quite long IR
73, Simone
Old 26-08-2005, 04:21   #7
...an here is a screenshot of the impulse response, which got shorter in the last hour
73, Simone
Old 30-08-2005, 19:39   #8
A first log on BBCWS 7465 kHz from Kvitsoy, not a good one in terms of reception. Signal was not weak but due to the big bitrate the audio decoding was not good. Oddly, the overall sound impression was over average, much better than anyone can realize looking at the log.
John
Old 30-08-2005, 23:31   #9
After transmission on 1296 kHz had ended, I tuned to 7465 kHz and found a strong signal.
Excellent result! 100%. I stopped logging shortly before 23:00 UTC to retune to the now DRM-free 1296 kHz channel in order to perhaps get some idea why I usually get an increase in SNR there shortly after 2300 UTC.
After I had returned to 7465 kHz later, transmission continued until about 23:09 UTC, again with 100% audio.
Kvitsoy looks like being a perfect TX site for my location.
Old 31-08-2005, 04:14   #10
here are my results of the complete 7 hours transmission, strong signal, long IR, signal was not synchronized with the signal from Rampisham, the dropouts at 1900 were caused by myself,
73, Simone
Old 31-08-2005, 05:53   #11
Very good reception. There were no audible dropouts, because UEP is working in the DRMSWR. Some UEP effects were audible.
@Roland you should update your drmtx.txt file from time to time. I added a lot of new frequencies recently.
Old 31-08-2005, 08:40   #12
Hi Carsten,
I had manually updated my old drmtx.txt file yesterday, but because the filename has been changed not long ago to drmtx.new and the old file is no longer used now (a fact, I already knew but had forgotten), it did not work and I did not check it after the change. I sometimes prefer to manually upgrade the file.
Old 31-08-2005, 16:20   #13
52°N 07°E
A short report from last night. Signal was still strong, but very deep fading sometimes causing dropouts.
Old 31-08-2005, 18:10   #14
52°N 07°E
No fun this early evening.
Interference from both sides, and a fast and deep fading on the signal.
Old 31-08-2005, 18:42   #15
I think there is a transmitter problem. The whole spectrum is jumping quite strong, I don't thing that this is fading. Never saw this before.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
