Old 22-09-2015, 06:08   #856
BBC WorldService logged for 59 minutes from 0500 UTC. 22.27 dB max. SNR and 48.26 % decoded audio.
Perhaps the Solar flare did influence the reception yesterday, perhaps it didn't. The reception was very much the same again here this morning.
Old 22-09-2015, 06:39   #857
22 Sep 2015 : BBCWS Woofferton 3955 kHz
69% overall decoded audio, 97% from 05:20 UTC.
03:00-06:00 UTC Planetary K-index: 1+. Local K-index: 1.
Planetary A-index: 9. Solar flux: 106. SWPC Sunspot number: 68.
200 km MUF: 4.1 MHz @ 05:00, 3.9 MHz @ 05:10 & 4.8 MHz @ 06:00 UTC.
Sunrise 05:48 UTC.
Old 22-09-2015, 07:15   #858
OT: Ionograms
Neil, which Ionogram are you looking at? Mostly I use Juliusruh as it is sort of halfway between my location and central Europe.
Old 22-09-2015, 11:06   #859
BBC 3955 KHz reception near Atlanta, Georgia, USA
The overnight reception from the back of the beam - no audio decoded, 8.28dB max SNR.
Old 22-09-2015, 20:47   #860
Ionosonde
Hi Terje, I use the ionosonde which is located at the Rutherford Appleton Laboratory. It is at a small village called Chilton (nearest town Didcot), which is about 35 km from my location, so should give me a good indication of my ionospheric conditions.
Old 23-09-2015, 06:29   #861
23 Sep 2015 : BBCWS Woofferton 3955 kHz
97% overall decoded audio.
Planetary A-index: 10. Solar flux: 109. SWPC Sunspot number: 79.
200 km MUF: 4.2 MHz @ 05:00, rising to 4.9 MHz @ 06:00 UTC.
Sunrise 05:50 UTC.
Old 23-09-2015, 07:08   #862
Thanks Neil,
I keep a list of different Ionogram sites. Ionograms are quite helpful sometimes. The reception of BBC this morning was not particularly good. Only 21.5% decoded audio.
Old 23-09-2015, 13:08   #863
The overnight reception from the back of the beam - no audio decoded, 7.44 dB max SNR.
Old 24-09-2015, 07:59   #864
This morning I used the DR111 instead of Dream. I logged for 58 minutes from 0501 UTC. 23 dB max. SNR and 87.26% decoded audio. At 0500 UTC the signal strength was 48 dBuV, around 0530 it had decreased to 37 dBuV and at stayed at that level until the end of the broadcast.
Old 24-09-2015, 11:42   #865
The overnight reception from the back of the beam - no audio decoded, 5.99 dB max SNR.
Old 24-09-2015, 20:43   #866
24 Sep 2015 : BBCWS Woofferton 3955 kHz
54% overall decoded audio, 98% from 05:30 UTC.
03:00-06:00 UTC Planetary K-index: 2-. Local K-index: 2.
Planetary A-index: 14. Solar flux: 108. SWPC Sunspot number: 95.
200 km MUF: 3.7 MHz @ 05:00, 3.9 MHz @ 05:30, rising to 4.8 MHz @ 06:00 UTC.
Sunrise 05:52 UTC.
Old 25-09-2015, 06:45   #867
25 Sep 2015 : BBCWS Woofferton 3955 kHz
96% overall decoded audio.
Planetary A-index: 8. Solar flux: 110. SWPC Sunspot number: 86.
200 km MUF: 4.2 MHz @ 05:00, dipping to 3.9 MHz @ 05:20, rising to 4.6 MHz @ 06:00 UTC.
Sunrise 05:53 UTC.
Old 25-09-2015, 06:49   #868
More or less the same result today. About 86 % decoded audio but 99 % decoded audio during the first 35 minutes.
Old 25-09-2015, 14:30   #869
The overnight reception from the back of the beam - 0.32% audio decoded, 13.55 dB max SNR.
Old 26-09-2015, 06:47   #870
26 Sep 2015 : BBCWS Woofferton 3955 kHz
52% overall decoded audio, 99% from 05:30 UTC.
03:00-06:00 UTC Planetary K-index: 0+. Local K-index: 1.
Planetary A-index: 7. Solar flux: 121. SWPC Sunspot number: 145.
200 km MUF: 3.8 MHz @ 05:00, 4.0 MHz @ 05:30, rising to 4.8 MHz @ 06:00 UTC.
Sunrise 05:55 UTC.
