Old 05-08-2019, 22:18   #1
KTWR 11580 kHz to South Asia
No signal at all noted here in New Zealand, August 5th @ 12:15-12:45 UTC
Had a quick look at reception on the TWR New Delhi KiwiSDR, but no decoding there either.
73 Chris
Old 06-08-2019, 01:04   #2
KTWR (Channel 1 Audio) to South Asia with a strong signal logged for 25 minutes from 1218-1243 UTC. Max. 18,96 dB SNR and 92,22% decoded audio. At 1215 UTC there was only a co-channel interferer, a weak AM signal probably SOH Xi Wang Zhi Sheng in Taiwan (?).
18,44 kbps, EEP, AAC, Mono, English, Religion, Guam, ID:1001.
A/10, 2s, 4/16, P:1/0, A:1/D:0 Timestamp: Mon. Aug.5 12:18:00 UTC+0.
Audio Bandwidth: 5000 Hz. The audio quality was clear and very good.
File Type: jpg 2019-08-05-11580-to-South-Asia-(in-Japan)_title.jpg (29.1 KB, 13 views)
Old 08-08-2019, 04:24   #3
Today I received a very nice e-QSL card for the 11580 kHz transmission from Monday the 5th August.
Old 13-08-2019, 00:27   #4
12th August 2019
Unfortunately there was no signal at my location (central Japan) for the South Asia transmission.
Old 13-08-2019, 12:48   #5
Nothing here in NZ. Non-KTWR analogue signal here.
Old 19-08-2019, 12:59   #6
via kiwiSDR in Shenzhen South China
via kiwiSDR in Shenzhen (just a stone's throw from Hongkong), South China
Fair signal, deteriorate towards the end of program. It's a pity the first 15 minutes is in silence. Probably they forgot to switch on the audio feed?
P.S. Have to change the name of the attached "log.zip" to "log.rar" to unzip the file
My Rx location: GuangXi Province @ E10636′ N2355′
Old 20-08-2019, 00:46   #7
The result (using your coordinates) was about 90% decoded audio. The DRM configuration was not Mode C as scheduled and they changed the Label to something understandable!
Old 20-08-2019, 00:52   #8
I did not expect much and that was what I got: Nothing. Except the Label "KTWR". According to their schedule they should use Mode C this week, but instead they changed to Mode B and aac+
Old 20-08-2019, 02:17   #9
Originally Posted by Digger
Thanks, Terje. I should have mentioned that the instances where SNR dropped to zero are all network related. By and large, signal is not very strong, but relatively stable.
