Old 24-01-2009, 09:02   #1
RDP Internacional via Sines on 9815 kHz
RDPi (Portugal) will start broadcasting in DRM via Sines on January 31st 2009.
Saturdays & Sundays only
0930-1100 UTC
9815 kHz
Target: Central Europe
DRM details and a form for reception reports is available at http://tv1.rtp.pt/EPG/radio/epg-dia....l=5&ac=d&sem=e
Old 31-01-2009, 08:32   #2
CT1ADT
CT1ADT's Avatar
RDPi on 9815 kHz -- > 9.30 - 11.00
Hi all
RDP Internacional, the Portuguese external service, start today an experimental DRM , all Saturday and Sunday beamed to Central Europe.
73īs Esteves
Kenwood TS-2000 + vertical antenna R7000 ( 8m )
MyDRMpage: http://www.qsl.net/ct1adt
CT1ADT is offline   Reply With Quote
Old 31-01-2009, 08:36   #3
Nice music, good signal but completly wrong configuration (Deutsche Welle, English, Information, Germany).
Just added the log.
Old 31-01-2009, 09:09   #4
Hi All
Some signs of the signal here in NZ, but they don't stand much of a chance here due to a massive signal on 9810 kHz from CNR China Business Radio. Now if only that were a DRM signal I could get some perfect reception!
73 Chris
Old 31-01-2009, 09:37   #5
Booming in, but disappointing Label.... I had hoped for something new... DW
Old 31-01-2009, 10:04   #6
Jan.31
Strong signal from Sines but Cina on 9820 with ton on 400Hz S9+10db/44dbuV .
Old 31-01-2009, 10:14   #7
Jan. 31
The signal was about 30 dBuV affected by QRM on 9820 kHz, IR a bit chaotic. Wrong label...
Old 31-01-2009, 10:16   #8
Ant-SWL
Ant-SWL's Avatar
RDPi 9815 KHz
Perfect reception here. (Two Dips in audio line probably from AM or Notebook here. )
73, Andy
Ant-SWL is offline   Reply With Quote
Old 31-01-2009, 10:22   #9
Threads merged, please always look for an existing thread before starting a new one.
Good results here too, same two dips as Andreas mentioned (plus an additional one).
Old 31-01-2009, 16:09   #10
sveron
sveron's Avatar
It seemed good here as the signal was strong on my ATS 909, but local interferences with multiple harmonics destroyed the reception, audible but that's all, not worth listening.
Stephane
Laptop or Desktop PC with DWT and Degen DE31/TG33. Lower domestic QRN since 2010.
sveron is offline   Reply With Quote
Old 01-02-2009, 10:09   #11
Feb. 01
The signal was a bit stronger today less affected by QRM on 9820 kHz.
Old 01-02-2009, 10:42   #12
Pirx
Hi!
RDP International (DW).
My receipt result.
Audio 98%.
Pirx is offline   Reply With Quote
Old 01-02-2009, 10:50   #13
Almost a perfect (unattended) log. Towards the end the SNR varies, QRM from -5 kHz?
Old 01-02-2009, 18:11   #14
Perfect apart from the two small dips (same times as yesterday, probably Tx related)
Old 03-02-2009, 05:01   #15
CT4RK
CT4RK's Avatar
Hi all
I was rectified the wrong label. I hope the next transmission will be ok.
73 from CT4RK
73 from: CT4RK
Carlos
Sines - Portugal
Receiver TENTEC RX320 modified, R&S HEO10 active antenna, DREAM software...And...No more PLC/BPL QRM...Thanks ANACOM!
Save the Radio Spectrum! Eliminate Broadband over Power Line.
CT4RK is offline   Reply With Quote
