Old 16-02-2010, 17:41   #31
Results as usual with a few small dips, I also had a closer look at the audio, seems the past days The Disco Palace was always mono despite the encoder settings being parametric stereo like on TDPradio, where I do get a stereo signal. I just checked on the internet, the webstream is in stereo.
File Type: png 6015-100216-1402-1459-simone_CIAO_H101.png (44.5 KB, 142 views)
Old 16-02-2010, 19:05   #32
Same small dips here. On big dip was my PC.
Old 17-02-2010, 14:56   #33
Good results but still only a mono signal despite the par. stereo configuration.
Old 18-02-2010, 17:06   #34
Only a few small dips, almost perfect results (still mono).
Old 19-02-2010, 14:18   #35
A few small dips, still mono, otherwise almost perfect results.
Old 20-02-2010, 15:16   #36
Typical results again today, audio still mono.
Old 21-02-2010, 19:20   #37
Similar results today, second log also covers the TDPradio transmission in the same log.
Old 22-02-2010, 14:55   #38
A few small dips as usual , audio still mono, otherwise pretty good results.
Old 23-02-2010, 14:49   #39
Good results as usual.
Old 24-02-2010, 15:08   #40
Typical results again today.
Old 25-02-2010, 14:57   #41
Good results again today, almost perfect.
Old 25-02-2010, 17:01   #42
PP5AZF-Ataliba
I suggested to Mathias CVC DRM 17,860 khz to change the mode B to Mode A and so remained until today. The rate of bitrate is 18 Kbps, mode A, P. Stereo. Here in southern Brazil, the signal is easily decoded. The audio quality is good, but it would be better if the rate was higher bitrate. A good equalization of frequency modulation of the audio before the audio DRM leave with much more quality.
Contact Mathias and ask if the results are good.
Mathias Svensson <mathias@cvclavoz.cl>
The sign of the TDP in the range of 17 Mhz is coming here but it is very weak, I am not able to decode the audio unfortunately.
Eu sugeri ao Mathias da CVC DRM 17.860 khz para mudar de mode B para Mode A e assim ficou até hoje. A taxa de bitrate está em 18 Kbps, mode A, P.Stereo. Aqui no sul do Brasil o sinal é facilmente decodificado. A qualidade do áudio é boa, porém seria melhor se a taxa de bitrate fosse maior. Uma boa equalização das frequências de áudio antes da modulação DRM deixaria o áudio com muito mais qualidade.
Entre em contato com Mathias e pergunte se são bons os resultados.
O sinal da TDP na faixa de 17 Mhz está chegando por aqui mas é muito fraco, não estou conseguindo decodificar o áudio infelizmente.
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 25-02-2010, 18:27   #43
lmaes
lmaes's Avatar
The Disco Palace now in stereo
Dear All,
We are happy to report that we have fixed the mono problem for The Disco Palace. So from now on, even better audio quality, because in stereo!
Hope you will enjoy even more. Any comments of course always welcome.
All the best,
Ludo
BTW : unbelievable or not, the problem was with ... Vista
lmaes is offline   Reply With Quote
Old 26-02-2010, 16:22   #44
Dear Ludo,
thanks for your message, great that the mono problem on The Disco Palace has been solved, so today I noticed for the first time that was in stereo. I listened in the car for about half of the broadcast today and that sounded pretty good
Old 27-02-2010, 15:23   #45
Good results again and audio in stereo.
