Old 13-08-2009, 06:55   #16
Last night (12th Aug.), after AIR ended, not heard, not read but seen. Very chaotic and weak signal here around 2235 UTC. The ID in the screen dump is the same as earlier sightings.
Old 13-08-2009, 23:05   #17
The reception was a bit better tonight. The "Echo des Tages" came through quite well and all the contents of Journaline in WAZ Nachrichten were decoded without problems.
Old 19-08-2009, 18:15   #18
18th August
Although I am outside the target area the decoding was very good last night. I got some interesting information on this test transmission by Media & Broadcast aimed to a ship "M/S Bremen" which is underway far North in the Arctic Ocean equipped with a DRM receiver. Among others, NDR gave permisson to use the "Echo des Tages"-Podcast for the first half hour of this transmission. However, nobody knows how long these tests will continue.
Thanks to Mr. M. Pulsmeier at NDR for this info.
Old 22-08-2009, 22:26   #19
It is no fun logging Nauen 9530 kHz here, so I gave up after some minutes.
Propagation is quite difficult, please have a look at the second file. Decoding was possible in this "deep orange" time only. Maybe anybody has an explanation for this unusual propagation?
@Digger: Thanks for your reserch. I contaced NDR too but reached the "wrong" person there.
Old 22-08-2009, 22:30   #20
Signal from WAZ but vet bad propagation HI delay and doppler som not audio.
Old 27-08-2009, 08:41   #21
A very short log. Stable reception for a change.
Old 31-08-2009, 20:45   #22
CT4RK
CT4RK's Avatar
Echo des Tages
Echo des tages very strong in Portugal. QRG 11.970 Mhz at 20:20 UTC
Perfect reception. No dropouts at all. The low SNR is due the QRM made by home plugs BPL/PLC systems.
73 CT4RK
73 from: CT4RK
Carlos
Sines - Portugal
Old 05-09-2009, 07:18   #23
I saw the label "Echo des Tages" on 11.970 MHz too here yesterday. I suppose this is also coming from Nauen, as reception is almost impossible here.
Old 07-10-2009, 12:23   #24
Siber
Siber's Avatar
9655 kHz WAZ Nachrichten
Does anybody else receive that object?
The signal received my friend Vladimir Mikhaevich from Tomsk. Tonight I'll try too
Siber is offline   Reply With Quote
Old 07-10-2009, 17:22   #25
Siber
Siber's Avatar
The strong clear signal... No MOT decoding...
Old 11-10-2009, 09:59   #26
Siber
Siber's Avatar
I have been continue observation of the signal.
Old 11-10-2009, 17:33   #27
I am in an awkward position to receive Nauen. But my DRM-Plotter succeeded in shooting a screenshot when conditions allowed some decoding.
The log was unattended. Btw, at 1705 there was just an AM station blaring on the frequency...
Old 11-10-2009, 20:09   #28
Now that's a pretty cool feature! I have to try this when I returne from my looooong absence of DRM reception.
Old 12-10-2009, 17:14   #29
A very strong signal tonight 20 minutes before close down. Unfortunately, my PC decided to hang up, so I did not get much in the log. Plus that I didn't get enough time to decode the MOT Web Site either.
Old 18-10-2009, 11:39   #30
Was visible here last Friday, first at 1600 UTC with Echo des Tages, later with a data service (no label decoded). Not worth posting the log here.
