Old 23-07-2010, 21:15   #181
Originally Posted by Digger
@Fritz: "If I look at the date of your post you must be far ahead of the time"
Terje, sorry, I deleted that after a very short time, was a mistake and only readable for a minute or so.
@Fritz: PS 23rd July 2010: At 60 deg N Kigali is a no-no... so far, anyway.
That's for sure! I was lurking on 25925 kHz for Poland all day and probably missed the best on 25740 kHz.
Old 27-07-2010, 11:55   #182
I hear to 23 July 10 Radio Kigali of 25740 Khz to little secondly SNR of 18 db and I have approximatif 1 minute audio reccording.
http://www.pictonale.net/2010/07/27/l9fgp9b/
Old 29-08-2010, 20:48   #183
No traces in Stockholm for this frequency, but the VOACAP confirms that, so there you are. The active antenna is not the best for 25 MHz, but was there traces of signal here in Switzerland this afternoon ???? Need to rig up a different antenna.
Old 30-08-2010, 15:38   #184
I was probably too late yesterday. The signal was visible around 14 UTC and faded out around 1530. Max 11.1 dB SNR on the active antenna. Needs a little bit more to decode audio. There is no label, although I informed Kigali.
Old 20-09-2010, 17:46   #185
Nada, nil, nothing all day long:
Old 21-09-2010, 11:25   #186
... but today there is something going on just now (1125 UTC) and 50 minutes ago, too...
A log from 1025 - 1252 UTC. After 1252 there wasn't a single bit to see. Nice to see Rwanda sticking up its signal through the noise before I leave for Sweden next month. In Stockholm the chances of seeing 25740 is virtually nil.
Old 22-09-2010, 17:26   #187
Today was not so good as yesterday...
Old 23-09-2010, 15:48   #188
Today I got 6.4% decoded audio between 1350 - 1410 in this 4 1/2 hours long log.
Old 24-09-2010, 19:38   #189
No log today. I used the active antenna and saw traces of signal at 1200, 1240 and 1310 UTC. Max SNR was 4.3 dB at 1200. Bad weather made it impossible to use the 27 MHz ground plane antenna.
Old 27-09-2010, 16:08   #190
Infinitesimally small amount of RF signal from Kigali this afternoon. Need a magnifying glass to see anythig in my log!
Old 28-09-2010, 13:05   #191
More signal today, but unfortunately, my GP antenna toppled over so I have to use the active antenna which is less effective above 25 MHz.
Old 29-09-2010, 13:50   #192
Today's log (with Audio)
Old 01-10-2010, 21:01   #193
Nothing at all yesterday, a bit more today. When I started the log, there were activity traces present in Dream for at least 15 minutes.
Old 08-10-2010, 17:55   #194
It is still active!
Old 08-10-2010, 20:25   #195
Originally Posted by FritzWue
It is still active!
Of course! The TX is made in Switzerland.
