DRM Reception Project Forums
Go Back   DRM Reception Project Forums > DRM Reception Project > Reception Results - Recent Posts
Old 2020-07-04, 17:22   #46
3 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
Both services had no audio! The English service had 91% decoded signal with the signal strength peaking to 68 dBuV, and an average of 63 dBuV.
Old 2020-07-06, 05:59   #47
4 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 93% decoded audio with the signal strength peaking to 71 dBuV, and an average of 63 dBuV.
Old 2020-07-07, 12:28   #48
5 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 96% decoded audio with the signal strength peaking to 73 dBuV, and an average of 67 dBuV.
Old 2020-07-07, 12:29   #49
6 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 94% decoded audio with the signal strength peaking to 72 dBuV, and an average of 66 dBuV.
Old 2020-07-08, 17:01   #50
7 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 99% decoded audio with the signal strength peaking to 76 dBuV, and an average of 65 dBuV. It should be noted that the transmission started 3 minutes late.
Old 2020-07-09, 17:06   #51
8 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 98% decoded audio with the signal strength peaking to 72 dBuV, and an average of 65 dBuV.
Old 2020-07-10, 18:38   #52
9 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 99% decoded audio with the signal strength peaking to 79 dBuV, and an average of 68 dBuV.
Old 2020-07-12, 15:46   #53
10 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 99+% decoded audio with the signal strength peaking to 75 dBuV, and an average of 68 dBuV.
Old 2020-07-12, 16:08   #54
11 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 99% decoded audio with the signal strength peaking to 74 dBuV, and an average of 66 dBuV.
Old 2020-07-14, 17:30   #55
13 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 98% decoded audio with the signal strength peaking to 68 dBuV, and an average of 62 dBuV.
Old 2020-07-16, 11:33   #56
14 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 98% decoded audio with the signal strength peaking to 74 dBuV, and an average of 66 dBuV.
Old 2020-07-16, 12:13   #57
15 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service finished early at 20:50 UTC. While transmitting there was 99% decoded audio with the signal strength peaking to 76 dBuV, and an average of 68 dBuV.
Old 2020-07-17, 18:21   #58
16 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 99% decoded audio with the signal strength peaking to 72 dBuV, and an average of 65 dBuV.
Old 2020-07-18, 07:06   #59
17 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 99% decoded audio with the signal strength peaking to 76 dBuV, and an average of 68 dBuV.
Old 2020-07-19, 09:28   #60
18 Jul 2020 : RRI on 7315 kHz from Galbeni @ 20:00 UTC in French & then in English
The English service had 93% decoded audio with the signal strength peaking to 67 dBuV, and an average of 60 dBuV.
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
Forum contents ©2003-2024 DRM Reception Project participants
