Old 09-04-2004, 19:24   #1
jbriggs
James Briggs
jbriggs's Avatar
Thumbs up RTL 6095 kHz
From today 9th April 2004 please post comments about 6095 kHz here.
Thanks, James
jbriggs is offline   Reply With Quote
Old 10-04-2004, 01:06   #2
Ok, I start with 600 minutes. Voltage Hitradio Paris. First I thought that I was a test loop, because most of the songs were played every hour again. But that is what they call heavy rotation
A lot of fading and not the strongest signal today. Sound quality was quite good.
Old 10-04-2004, 10:29   #3
here are the typical results for RTL (on both frequencies) in the morning
73, Simone
Old 10-04-2004, 15:44   #4
radiomann
radiomann's Avatar
Great reception again, though I only logged it for 1hr 40mins(ish) it's been solid all day, comes in about 8am and stays.
Paul
radiomann is offline   Reply With Quote
Old 11-04-2004, 14:05   #5
radiomann
radiomann's Avatar
Hi all
yet another 8 hour solid performance, see below.
Paul
Old 11-04-2004, 18:13   #6
good results later this morning, see attachment
73, Simone
Old 12-04-2004, 20:53   #7
Good reception until 19 UTC. Very weak in the morning. Today the RTL programme with the best sound quality. But I noticed some strange dropouts that were not caused by reception problems. Sometimes the audio feed is interrupted for several seconds. It does not matter what programme is on 6095 khz
Old 13-04-2004, 16:42   #8
lx1nw
Michel Asorne
Dear all,
now that most modifications on our 5990kHz transmitter are applied, we will proceed to some additional transformations on the 6095kHz transmitter. For this reason there will be no DRM broadcast on 6095kHz during the next 2-3 days. Hopefully we will be on air again for the weekend.
Michel
lx1nw is offline   Reply With Quote
Old 13-04-2004, 20:58   #9
lx1nw
Michel Asorne
Never the less, here are my results on todays' RTL DRM transmissions, about 40 km south-west of the transmitter site.
RX: TS-440S, 10kHz IF filter
Ant: Wellbrook active magnetic loop
73 Michel
Old 17-04-2004, 02:15   #10
lx1nw
Michel Asorne
unfortunately we have not been able to finish our modifications before the start of the weekend, so the transmitter will not be in operation until monday or tuesday.
Michel
Old 21-04-2004, 06:24   #11
lx1nw
Michel Asorne
Dear all,
our modifications seem to take more time than expected. We nevertheless hope to be able to be back on air as soon an possible.
Michel
Old 22-04-2004, 18:10   #12
Hi Michel,
surprisingly found RTL back on air on 6095 kHz this afternoon, using 20.9 kbps param. stereo when I started, later reduced bitrate (17.4 kbps mono), see results of 2.5 hours log attached
73, Simone
Old 22-04-2004, 18:19   #13
CT1ADT
CT1ADT's Avatar
Hi Michel
For my location the frequency of 5990 kHz is better that 6095 kHz... reason? The transmiter has more power or the antenna has more gain? or I am in the target area of the antenna ?
73īs Esteves
Kenwood TS-2000 + vertical antenna R7000 ( 8m )
MyDRMpage: http://www.qsl.net/ct1adt
CT1ADT is offline   Reply With Quote
Old 22-04-2004, 18:42   #14
radiomann
radiomann's Avatar
Here's my 10 hour or so log, very good, also like the new schedule, more music.
Paul
Old 22-04-2004, 19:55   #15
Very strong signal this morning from 6-7 UTC. It was the french RTL 2.
