Old 12-12-2018, 05:08   #1
alokesh
KTWR Christmas DRM Broadcast Schedule
Japanese - Towards Japan
15 Dec 2018 1100-1130 UTC 9910 kHz 50 kW
16 Dec 2018 1245-1315 UTC 7500 khz 50 kw
22 Dec 2018 1100-1130 UTC 9910 kHz 50 kW
23 Dec 2018 1245-1315 UTC 7500 kHz 50 kW
English - To South Asia
24 Dec 2018 1245-1315 UTC 9380 kHz 75 kW
25 Dec 2018 1245-1315 UTC 9380 kHz 75 kW
English - To ANZ/South Pacific
24 Dec 2018 1030-1100 UTC 11995 kHz 50 kW
25 Dec 2018 1030-1100 UTC 11995 kHz 50 kW
Note : Stereo mode B 64 QAM to Japan and ANZ/SP and mono mode A 16 QAM to India.
Alokesh Gupta, VU3BSE
New Delhi, India.
Old 15-12-2018, 11:36   #2
This transmission was seen on a Kiwi SDR in Nagano 150 km north of my QTH with a strong signal. But here in Shizuoka there was not much to enjoy. The transmission ended early and went on in English/Japanese in AM mode.
Old 15-12-2018, 21:36   #3
9910 kHz 1100 UTC December 15
0.8% decoded here in NZ - far too many other ute signals on that channel here.
Old 15-12-2018, 22:02   #4
Slightly better via the NZRDXL's KiwiSDR in Northland, NZ - 4.7% decoded...
Enough to hear the odd word of Japanese.
Old 16-12-2018, 13:28   #5
An informal reception via KiWiSDR in Lanzenhäusern, Switzerland. Good signal and good audio, but poor freq choice due to interference from lower 5KHz AM broadcast from 1300 UTC.
My Rx location: GuangXi Province @ E106°36′ N23°55′
Old 16-12-2018, 23:26   #6
7500 kHz December 16th
Signal on 7500 kHz quite strong here in NZ, but not worth logging due to massive signal on 7505 kHz.
Old 17-12-2018, 00:20   #7
I messed everything up last night so no log. I was not in at the time, so I have no further comments.
Old 22-12-2018, 12:07   #8
Again via KiWiSDR in Tokyo, Japan. Very strong and stable signal for the whole test session. Perfect audio decode despite the adjacent channel interference.
Old 22-12-2018, 13:09   #9
11H10 UTC I receive KTWR TEST of 9910 Khz many fading, signal from 5 to 11,7 db audio only 5% :
https://nsa39.casimages.com/img/2018...0954461284.jpg
Old 23-12-2018, 00:27   #10
22nd Dec.
About 54% decoded audio. The signal varied between S5-S6 and sometimes up to S9 with QSB. The Channel Impulse Response was very good, so I wonder why the SNR was so low?
Old 23-12-2018, 13:41   #11
Dec_23
Weak signal. 0.00% CDA, 11.2dB max SNR. At 13:00 QRM on 7495kHz started. I got the label.
Old 23-12-2018, 16:42   #12
At the beginning of the broadcast the signal was low SNR 4db then it began to climb and this until the end where there was SNR 18,8 db, but following the fading of many audio clippings.
https://nsa39.casimages.com/img/2018...4300556287.jpg
https://nsa39.casimages.com/img/2018...4445643468.jpg
https://nsa39.casimages.com/img/2018...4840567014.jpg
https://nsa39.casimages.com/img/2018...4412733034.jpg
Old 24-12-2018, 02:21   #13
23rd Dec.
KTWR Guam with a test towards Japan logged for 29 minutes from 1246 UTC.
Max.19,05 dB max. SNR and 35,11% decoded audio. The transmission ended early.
Old 24-12-2018, 11:19   #14
24th Dec.
Traces of signal and the label was seen in Japan for this 11995 kHz transmission in English. Max. 6.55 dB SNR.
Old 24-12-2018, 12:59   #15
Radioeng
KTWR 9380 kHz
This transmission started at 12.15 and ended at 12.45 UTC. Good reception using a KiWiSDR in Western Australia that I used for the 10.30 UTC broadcast to that region.
Radioeng is offline   Reply With Quote
