Old 29-10-2016, 13:00   #1
Test Rádio Nacional da Amazônia (Brazil) 9750 kHz
In this weekend, our public brazilian radio will be broadcasting on 9750 kHz in DRM mode, with low power, 125 W. I could listen it in Rio de Janeiro, 1210 Km long.
Video: https://youtu.be/SlOTLq-g1lU
Old 30-10-2016, 06:05   #2
PP5AZF-Ataliba
EBC DRM 9750 khz - 150 watts- Brasilia-DF - Brazil
Testing with DRM on shortwave resumed in Brazil by EBC in the frequency of 9750 kHz (band 31m).
After some research and development of equipment for ABRADIG (Associação Brasileira de Radio Digital), tests were taken in order to assess the behavior of equipment, signal quality and system stability. Because the tests are being carried out at low power (150 W), is not expected great coverage.
Localization: I am located in the City of São José Santa Catarina state, a distance of 1,335 kilometers of Brasilia, south of Brazil, at an angle of 182 degrees from the transmitting antenna.
https://www.google.com.br/maps/dir/-15.6058675,-48.128625//@-23.9334346,-50.5359833,2869283m/data=!3m1!1e3
PP5AZF - GG52QK
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 30-10-2016, 06:08   #3
PP5AZF-Ataliba
EBC DRM 9750 khz - antenna radiation lobe
The main lobe of the antenna radiation is directed to the CONESUL and has a 15 degree elevation angle.
File Type: jpg EBC - lobulo irradiação antena direcional 16 dB.jpg (98.7 KB, 185 views)
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
Old 30-10-2016, 16:40   #4
pksato
pksato's Avatar
Last night (Oct 29) a received few minutes of EBC test transmission, and record this video of listen on Morphy Richards 27024.
https://youtu.be/MxdTnHBsnDw
I am 1000 km far from the site of transmission.
Now, Sunday afternoon, a getting some intermittent audio decoding.
http://www.drm-brasil.org/
Paulino - 21°S 51°W
pksato is offline   Reply With Quote
Old 30-10-2016, 17:34   #5
Another DRM broadcast with a MSC of 16 QAM on shortwave ... I can hardly believe it! Congratulations... Hopefully, listeners in North America will one day be able to listen to DRM broadcasts in a robust mode from Brazil and other countries in South America.
Old 30-10-2016, 20:06   #6
Hi All
I've seen very faint traces of a DRM signal on 9750 kHz from here in New Zealand the last couple of nights. It's only been barely visible in my SDR display, and too weak to get any sync or decode any id. I emailed Rafael Diniz and he confirms that their transmitter is having the occasional dropouts like I've seen in my reception. So, the signal is getting out :-) Here in NZ it fades in aroud 0630 UTC and is noticeable until blocked at 07:55 UTC. I suspect the antenna direction and signal path are just right at that time - if only there were a few more watts of power or a more perfect ionosphere
Old 30-10-2016, 20:32   #7
Hi Chris,
Yes, according to the VOACAP program (please see attached) you should get at least an S6 signal with a six foot vertical whip!
Congratulations on the excellent DRM DX!!
34°02' N, 84°24' W
Old 30-10-2016, 23:10   #8
30 OCT
Any signal in Resende - Rio de Janeiro, 1210 KM long. Good audio quality with 0,00083 times smaller than the power station AM. This is the moments with audio decoding: https://youtu.be/uclbHKbtBAw
Old 31-10-2016, 00:48   #9
PP5AZF-Ataliba
EBC DRM 9.750 khz - Brasilia-Brazil-125watts
A small sample 10 minutes:
Decoded audio: 27.86%
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
Old 31-10-2016, 01:13   #10
PP5AZF-Ataliba
DRM Log Plotter reception on Sunday evening
http://i.imgur.com/5ol8mE8.png
https://youtu.be/NlZsEhETSxs
Maringá City - Estado do Parana
The city of Maringa is 950 km from the transmitter
Paulino Kenji Sato
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
Old 31-10-2016, 12:54   #11
PP5AZF-Ataliba
EBC DRM 9.750 khz - Brasilia(Brazil) 125watts
DECODED AUDIO 08:22-08:56: 1,44%
Power DRM: 125 watts
Distance: 1.335 km
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
