Old 15-05-2013, 04:58   #1
17715 kHz AIR India to E Africa
I've been seeing this one on a regular basis here in NZ, but never good enough for any decoding.
I see the online DRM schedule seems to have all the AIR broadcasts entered in IST instead of UTC? It shows this transmission at 1000 UTC, but other sources on the net (eg short-wave.info) show this broadcast correctly.
Old 03-05-2014, 05:09   #2
A little bit of signal here on 17715 kHz today - enough to get the id but that's all.
Old 11-05-2014, 09:02   #3
I saw this one by "mistake" early this morning while looking for something else. Only two minutes in the log.
Old 24-05-2014, 05:41   #4
Logged a few minutes of this AIR transmission today in NZ, between checking on RRI transmissions. No decoding possible though.
73 Chris
Old 07-07-2014, 09:39   #5
Weak signal at 04 30 UTC no audio only label as HINDI
Old 20-11-2014, 08:27   #6
I tried to log 17715 kHz this morning and set the DRM-Plotter to 0315-0530 according to AIR's schedule on their web page. No traces in the log before 05 UTC but after that the signal improved and I got 0.04% decoded audio. Now I wonder, did the transmission really stop at 0530 UTC?
Old 06-12-2014, 13:23   #7
PP5AZF-Ataliba
There were a few moments of audio decoding
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 07-12-2014, 04:33   #8
PP5AZF-Ataliba
Decoded audio 82.6%
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
Old 10-12-2014, 04:13   #9
PP5AZF-Ataliba
Talking
Vídeo (amostra): https://dl.dropboxusercontent.com/u/...41210-0230.mp4
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
Old 04-01-2015, 18:01   #10
PP5AZF-Ataliba
AIR DRM 17.715 khz received in Brazil (03.01)
AIR DRM 17.715 khz received in Brazil (03:01):
https://www.google.com.br/maps/@-27.5790156,-48.6166986,2127m/data=!3m1!1e3
Dipole (inverted V) antenna for 7.1 mhz
Distance: 14.741 km - azimuth 75º
Decoded audio: 99,01% (03:48-04:19h UTC).
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
Old 16-01-2015, 05:23   #11
Today it was labeled Vividh Bharti with 14.12 kbps. I logged it for 76 minutes. No audio and high Doppler.
Old 22-02-2015, 07:46   #12
In absence of RRI I tried AIR. "HINDI" today and no luck at all.
Old 23-02-2015, 05:11   #13
It was HINDI today again and the configuration was 4/64 and 20.88 kbps. Result: Of course nothing at all.
Old 04-03-2015, 03:30   #14
PP5AZF-Ataliba
03:27 - 03:33h UTC - decoded audio 99,48%
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
