Old 30-10-2005, 08:38   #1
Baldo34
Baldo34's Avatar
Radio Luxembourg on 7295
Radio Luxembourg now on this new frequency.
Only 8 dB at my location, should be much better in the UK.
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 30-10-2005, 08:54   #2
Andreas
Junior Member
Andreas's Avatar
22 to 23 dB over here! I will log that another time.
Thanks for the info!
73, Andreas
Andreas is offline   Reply With Quote
Old 30-10-2005, 10:14   #3
radiomann
radiomann's Avatar
Started off ok but then tx problems/maintenance? Switches back to analouge.
Paul
radiomann is offline   Reply With Quote
Old 30-10-2005, 14:08   #4
Andreas
Junior Member
Andreas's Avatar
Compared to last weeks log of 7145 kHz signal is slightly stronger, but sync losses and/or interruptions in datastream seem to continue . These caused the drop outs except the one at 14:45 which was my fault.
Sound quality is good and near to the historic original
Old 30-10-2005, 15:37   #5
radiomann
radiomann's Avatar
Early finish on this freqency though
Paul
Old 31-10-2005, 12:22   #6
Not too bad, even if I'm not in the target area. At 1300 UT a carrier started modulating a 2 kHz tone intermittently, which totally downed Luxy.
Old 31-10-2005, 14:54   #7
radiomann
radiomann's Avatar
Todays report, better but keep loosing sync/audio but the spectrum is ok. I also see 7145 starts up when 7295 stops.
Paul
Old 31-10-2005, 15:07   #8
some dropouts at the beginning were Tx related, after 1240 signal was too weak for decoding, see attachment
Old 31-10-2005, 15:08   #9
The TX 5 kHz up eventually stopped broadcasting whatever it was, and here is the rest up until approx. 1545 UTC.
73
Old 31-10-2005, 18:52   #10
7295
Hi all .
7295 Khz is in my QTH very good.
My S meter peak S9+20dB an SNR is 18-20dB.
1150UTC start AM om 7290 and drop outs direct.
Luxy , move back to 7145 1600UTC
Old 02-11-2005, 18:17   #11
Hi All
Some signal is getting as far as New Zealand, but nothing good enough for any decoding using DRT1. I'm suprised to see anything at all in my log, considering the distance and time of day.
Old 03-11-2005, 19:31   #12
Her is my report from this day, 7295 is in my QTH very good ,free from AM this time.
7295 is very strong S9+20-30dB , very fast QSB from time to time.
98%CDA.
Old 05-11-2005, 14:11   #13
Bob
Good SNR today, 11:00 - 15:00, decoding 97% but a lot of drop-outs.
regards
Bob
Winradio G303Pro, RCA AR-88D/Sat-Service Schneider LC mixer, plus Wellbrook LA5030 Indoor Loop, longwire antenna
Bob is offline   Reply With Quote
Old 05-11-2005, 14:55   #14
radiomann
radiomann's Avatar
Todays report, some of the dropouts on the graph I never heard.
Paul
Old 08-11-2005, 16:59   #15
radiomann
radiomann's Avatar
Unmanned log for today.
Paul
