Old 17-08-2019, 10:04   #31
Aug_16
I received the transmission, between two interfering AM carriers. I got some German speaking audio as well as the label and I run a log. See both attachments.
Old 17-08-2019, 13:36   #32
Pretty much the same result here, both gave a label but the 9 MHz broadcast was a lot stronger and gave me a bit of audio.
Maybe conditions will be a bit better for the September tests.
Modified NRD-525G with Radiokit DRM Decoder Board,
SDRplay RSP-1A, Airspy HF+ Discovery, Dream v2.1.1
Lancashire, UK 53:39.18N 02:10.28W IO83vp
Old 01-09-2019, 17:37   #33
DRM Hdn
DRM Hdn's Avatar
11990 kHz 1700-1800 UTC
No chance for a reception here in germany!
i saw a very little signal via websdr from hungary...without a chance for decoding. thats only sad!
Regards from Elbflorenz,Saxony
DRM Hdn is offline   Reply With Quote
Old 01-09-2019, 18:21   #34
DRM Hdn
DRM Hdn's Avatar
9540 kHz 1800-1900 UTC
Same disaster on this frequency
Old 01-09-2019, 18:40   #35
Sept_01 RTI 9540 kHz
The transmission started earlier and still is running.... Bad results.
(Transmission ended at 19:00.)
Old 01-09-2019, 19:08   #36
MARCEL
No signal in Northeast France of 11990 Khz.
DRM:
Mixer Platine MF9 Mhz with Dream
Antenna:
Mantova Turbo 5/8 wave for 27 mhz
Long Wire 80 meter
MARCEL is offline   Reply With Quote
Old 01-09-2019, 19:14   #37
MARCEL
Bad signal of 9540 Khz is very difficult to receive RTI just 3 secondly audio :
https://nsa40.casimages.com/img/2019...2017579464.jpg
DRM:
Antenna:
Long Wire 80 meter
Old 15-09-2019, 19:10   #38
Sept_15 - RTI on 9540 kHz
Good signal. A result for 14 mins @ 99.5% CDA / 21.4dB max SNR.
Old 15-09-2019, 23:58   #39
@John: I was asleep (and I forgot about it too). Could you tell me if the audio was as bad and distorted as it used to be?
Old 16-09-2019, 09:06   #40
@Terje, yes audio distorted due to over-modulation.
Old 16-09-2019, 11:42   #41
Aha, they never learn... time to take a trip to Taiwan ... !!
