Old 02-12-2017, 07:55   #76
1 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 68% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 3-. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 1+. Local K-index: 1.
Planetary A-index: 11. Solar flux: 72. EISN Sunspot number: 0.
Sunrise 07:46 UTC.
Old 02-12-2017, 18:42   #77
2 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 93% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 1-. Local K-index: 0.
Planetary A-index: 8. Solar flux: 71. EISN Sunspot number: 0.
Sunrise 07:48 UTC.
Old 03-12-2017, 22:59   #78
3 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 96% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 4. Solar flux: 70. EISN Sunspot number: 0.
Sunrise 07:49 UTC.
Old 04-12-2017, 19:30   #79
4 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 64% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0+. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 1. Local K-index: 0.
Planetary A-index: 2. Solar flux: 69. EISN Sunspot number: 0.
Sunrise 07:50 UTC.
Old 05-12-2017, 22:26   #80
5 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 89% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 3. Local K-index: 2.
Planetary A-index: 11. Solar flux: 68. EISN Sunspot number: 0.
Sunrise 07:52 UTC.
Old 09-12-2017, 07:54   #81
8 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 53% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 1. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 2-. Local K-index: 1.
Planetary A-index: 10. Solar flux: 68. EISN Sunspot number: 0.
Sunrise 07:55 UTC.
Old 11-12-2017, 18:39   #82
9 Dec 2017 : RRI on 9770 kHz from Tiganesti
03:00-06:00 UTC Planetary K-index: 0+. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 0. Local K-index: 0.
Planetary A-index: 5. Solar flux: 69. EISN Sunspot number: 0.
Sunrise 07:56 UTC.
Old 11-12-2017, 18:55   #83
10 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 85% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 1-. Local K-index: 1.
Planetary A-index: 4. Solar flux: 71. EISN Sunspot number: 0.
Sunrise 07:58 UTC.
Old 11-12-2017, 23:15   #84
11 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 80% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 3. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 2+. Local K-index: 2.
Planetary A-index: 3. Solar flux: 72. EISN Sunspot number: 7.
Sunrise 07:59 UTC.
Old 12-12-2017, 17:27   #85
12 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 69% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 2. Local K-index: 1.
Planetary A-index: 10. Solar flux: 72. EISN Sunspot number: 13.
Sunrise 08:00 UTC.
Old 13-12-2017, 20:36   #86
13 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 86% decoded audio during the transmission.
06:00-09:00 UTC Planetary K-index: 1. Local K-index: 1.
Planetary A-index: 13. Solar flux: 71. EISN Sunspot number: 0.
Sunrise 08:00 UTC.
Old 14-12-2017, 22:23   #87
14 Dec 2017 : RRI on 9770 kHz from Tiganesti
There was 76% decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 1+. Local K-index: 1.
Planetary A-index: 7. Solar flux: 72. EISN Sunspot number: 0.
Sunrise 08:01 UTC.
Old 16-12-2017, 07:40   #88
It seems I was lucky
100% audio this morning
SNR between 25 and 33 dB
This signal was the strongest in the band
73
Old 06-12-2018, 09:05   #89
RRI SNR Tiganesti E1 noted here in NZ on 9770 kHz on December 6th. A weaker signal than the preceeding transmission on 9770 from Galbeni, and suffers even more from interference from RNZI AM signal on 9765 kHz. No decoding.
Old 09-01-2019, 07:30   #90
RRI SNR Tiganesti E1 RRI German service @ 0700 UTC. Received in NZ with a strong signal, but 0% decoding due to RNZI AM signal on 9756 kHz.
73 Chris
