Old 11-12-2017, 18:59   #1276
Originally Posted by G0SVN
So if I understand it correctly, the antenna that is used for 15120 kHz is a fixed curtain that can be either beamed at 0 or 285 deg. Do I understand this correctly?
It is my current understanding that there are two fixed antenna arrays, one beaming 0 deg and the other 285 deg. The 15120 transmitter "can" be switched from one antenna to the other. Although I don't know if the feedline switches are actually in an operable state.
Old 11-12-2017, 19:44   #1277
Dec 11th, 2017 partial log ...
Old 11-12-2017, 23:10   #1278
Would be a good thing to ask Bodo about it.
Old 12-12-2017, 15:48   #1279
Abuja Antennas
Hi Terje, good to see your first post from Japan! I will see if I can make contact with Bodo via email and get the information first hand!
Old 12-12-2017, 17:55   #1280
Hi Neil & Terje,
My information on the antennas came from Bodo two years ago (Terje was copied on it). I don't think they would have physically changed the antenna structures in that time.
Old 12-12-2017, 18:58   #1281
Voice of Nigeria 15120 kHz reception near Atlanta, Georgia, USA
This afternoon's reception report - the early SNR peaks at around 1552 are probably DReaM software spurious phantom spikes.
Old 12-12-2017, 20:57   #1282
Dec 12th, 2017 log ...
Old 13-12-2017, 17:01   #1283
12 Dec 2017 : Voice of Nigeria on 15120 kHz from Abuja
The transmission was monitored from 18:30 UTC and there was 53% decoded audio during the transmission
15:00-18:00 UTC Planetary K-index: 3-. Local K-index: 4.
18:00-21:00 UTC Planetary K-index: 4-. Local K-index: 4.
Planetary A-index: 10. Solar flux: 72. EISN Sunspot number: 13.
Sunset 15:54 UTC.
Old 13-12-2017, 19:38   #1284
The logger showed no signal received this afternoon (13 December 2017).
Old 13-12-2017, 23:38   #1285
Dec 13th, 2017 log ... I logged very little, but the digital broadcast was present. The maximum SNR was only 4 dB so I decided to destroy the log as it wasn't worth posting. The broadcast appeared late (propagation?) at my location, about 1817Z. Overall, the signal was VERY weak.
Old 14-12-2017, 23:12   #1286
The logger showed very minimal signal (14 December 2017).
Old 15-12-2017, 20:41   #1287
Dec 14th and 15th, 2017 logs ... Dec 14th was poor to say the least.
Old 16-12-2017, 19:39   #1288
This afternoon's reception - 0.22% audio decoded, about 7 dB max SNR.
Old 16-12-2017, 20:16   #1289
Dec 16th, 2017 partial log ...
I've acquired a new laptop with a touch screen (past few laptops have either caught fire or other problems) which is probably excessively noisy *, but I'll try it with my SDR-4+ and DReaM for awhile. I'll likely be purchasing the GR-216 in a few months.
* I wanted a touch screen for use with Rivendell on GNU/Linux when I broadcast LPAM on the MW band.
Old 17-12-2017, 20:56   #1290
Dec 17th, 2017 log of TWO hours ...
