Old 20-05-2011, 12:43   #1
15775 kHz The Disco Palace from Issoudun to India
From today there will be daily transmissions for The Disco Palace to India:
Code:
Days: daily Time: 1530-1630 UTC Transmitter: Issoudun Alliss 100 kW DRM Frequency: 15775 kHz Antenna: HR 4/4/0.5 Azimuth: 79 degrees Program: The Disco Palace Language: English Target area: India
Please post results and comments here.
Results from previous tests can be found here
Thanks
Old 20-05-2011, 16:56   #2
Surprisingly good results today, a delayed start, correct configuration.
Old 20-05-2011, 20:30   #3
Pirx
This is my reception result.
Pirx is offline   Reply With Quote
Old 21-05-2011, 16:42   #4
I was late, so only the last minutes.
Audio was stuttering sometimes.
Decoding was best with time sync tracking on first peak.
Old 21-05-2011, 17:19   #5
A weaker signal in the first half, perfect decoding in the second half but several audio breaks.
Old 22-05-2011, 16:39   #6
Not so good in the first half, mostly due to heavy thunderstorms in my area, results improved in the second half, some audio feed problems again.
Old 24-05-2011, 20:53   #7
Mostly a weak signal today, only a short moment with audio decoding.
Old 25-05-2011, 16:44   #8
Excellent results today.
Old 26-05-2011, 17:32   #9
A few dropouts today.
Old 31-05-2011, 16:55   #10
Bad results today, only a few minutes when audio decoding was possible.
Old 31-05-2011, 19:29   #11
I thought this was bad, but it is not the target area. 15 MHz is a pain in the neck with the Elektor - I noticed that in Japan too. Some squirts of audio blasted out of my speakers anyway. Btw, I think this is the first log for this QRG.
Old 01-06-2011, 05:27   #12
mvs sarma
Earlier the listings of stations used to show up the coverage area in a map/
where do i find these for the new stations like the disco palace beaming towards India on 15775.
I am of the opinion, that the beam is facing New Delhi, our capital and far south in Hyderabad, the signal is neither present nor too weak. perhaps a signal map would help.
Sarma
Old 01-06-2011, 05:58   #13
ramvsankar
Sarma Ji,
I'm also having the same concern. I can tune here in Singapore with 28dB SNR !!?? and the beam line to France to Singapore, and it via Hyderabad, so why you cant rcv or no signal?? strange...
my youtube clip http://www.youtube.com/watch?v=4ykiFfQpTYQ
ramvsankar is offline   Reply With Quote
Old 01-06-2011, 21:31   #14
Hi Sarma,
I ran the transmission parameters through the VOACAP area program, and the result is attached.
Old 04-06-2011, 16:39   #15
A lot of fading plus an fsk signal on frequency and then the propagation was suddenly gone:
