Old 14-06-2013, 13:11   #1
Mitsuru Ito
Thumbs up KTWR on 12040KHZ
Signal was 20dB orver S9 on S-metter-
of IC-R75.
time 12:28-12:58 on 12040KHZ
14,15 Jube 2013
DE JA2QDX M.Ito
Mitsuru Ito is offline   Reply With Quote
Old 14-06-2013, 13:17   #2
DRM-Belarus
DRM-Belarus's Avatar
Unfortunately, no great shakes here in Minsk :-( Nor label neither configuration identified.
DRM-Belarus is offline   Reply With Quote
Old 14-06-2013, 14:49   #3
KTWR test on 12040 kHz
The signal was rather weak in Scandinavia as Mike predicted. No problem to get the label, but that was about all. I wonder if Mitsuru-san could see the slide show pictures in Japan?
Old 14-06-2013, 20:42   #4
Mitsuru Ito
hai Digger.
I was not able to see side show.
I wonder my dream was old.
There was strong AM station on 12045KHZ.
But signal has stopped at 12:00.
please try to receive on 15/06/2013.
DE JA2QDXM.Ito
Old 14-06-2013, 22:56   #5
No signal at all here in New Zealand. Not even a trace of DRM.
Old 15-06-2013, 08:15   #6
On the DRM Blog from Hiroshi in Japan ( http://drm.mediacat-blog.jp/ ) there is a comment on the KTWR slide show which was an XML file with IDs of different DRM stations.
Today's report is a little bit better than yesterday's. I could hear the sign-on in Japanese and English, but it was not possible to follow the conversation.
Text Message: "You are listening to KTWR Guam. Reception reports may be sent to: Trans World Radio, PO Box 8780, Agat, Guam 96928 or they" (I did not see the "or" bit).
Old 15-06-2013, 13:06   #7
DRM DX today . Very low signal stringth . Only S5=10dbuV !!!! But CDA 24,93% ok.
Old 15-06-2013, 13:17   #8
Mitsuru Ito
in JAPAN
few audio frames were missing today.
DE JA2QDX M.Ito
Old 15-06-2013, 21:45   #9
Slightly stronger here in NZ this time - at least I could tell there was a DRM signal on the frequency - but nothing worth logging.
