Old 03-11-2005, 12:29   #1
Baldo34
Baldo34's Avatar
RMC tests on 6175
RMC tests now on the new frequency 6175 kHz (ex 6165).
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 03-11-2005, 16:15   #2
GRUSON
Yes, RMC programme is currently broadcasted in DRM on 6175 kHz by MCR (a subsidiary of TDF) from Fontbonne near Monaco with only 10 kW DRM into a CHR 2/ 1/ 0.3 antenna beamed to Paris. Reception could be also possible during day in south of Germany, Switzerland, Luxembourg... RFI is not using 6175 kHz frequency at this moment so it is convenient for RMC/MCR tests.
Reports welcomed.
All the best from Jacques.
GRUSON is offline   Reply With Quote
Old 04-11-2005, 12:57   #3
Salut Jacques et tous,
only a weak signal this morning in Frankfurt, see attachment
Old 04-11-2005, 17:31   #4
GRUSON
Salut Simone and all!
Nice to hear from you again, Simone!
Thanks for RMC / MCR report, it could be better earlier in the morning or late afternoon but this transmission is not targeted to Germany.
Regards, 73.
Jacques
Old 05-11-2005, 10:06   #5
Bob
It's quite a long time since I checked this frequency - pretty good reception today from 09:55 - 11:00.
regards
Bob
ps I noticed that in Dream the SD CRC indicator was constantly yellow for this transmission even while MSC CSC was green and audio was decoded. Also there was no station text displayed (Right hand part of Dream Window) although there was a station label. Did anyone else have this ?
Winradio G303Pro, RCA AR-88D/Sat-Service Schneider LC mixer, plus Wellbrook LA5030 Indoor Loop, longwire antenna
Bob is offline   Reply With Quote
Old 05-11-2005, 10:09   #6
Signal only between S7 and S8 but nearly perfect results and quite high SNR! Perfect listening.
Old 05-11-2005, 11:43   #7
Salut Jacques,
great to hear from you again, good results at the beginning this morning.
@ Klaus: Seems there is another error in the schedule, yesterday and today transmission started at 0700 (not 0600)
73, Simone
Old 06-11-2005, 11:27   #8
Good rf results this morning, although in DREAM SDC CRC was constantly yellow.
The audio quality at 14.56kbps is not adequate for DRM, it sounds very similar to what I hear when receiving a local longwave or mediumwave AM station.
...and we all know that most listeners were lost there because of the better audio quality on FM.
DRM and this low bitrate make no sense in the long run.
Old 06-11-2005, 11:27   #9
perfect decoding today, although signal got weaker in the second half. Again low bitrate and no SBR, no text messages, with reception like this it should be possible to change the coderate and use SBR, but don´t know how it is in the target area.
Btw, seemed there were still errored data in the SDC!
Old 06-11-2005, 16:36   #10
Not so good this afternoon.
Old 07-11-2005, 15:21   #11
Salut Hervé, Jacques et tous
A short report from this afternoon shows a much better result compared to the previous QRG.
Old 07-11-2005, 16:01   #12
quite good results this morning, still a problem with the SDC.
Old 08-11-2005, 09:17   #13
Here my log from 7:00 - 10:00 UTC. 100% audio and a good, stable signal this morning.
Old 08-11-2005, 12:52   #14
6175
Salut Hervé, Jacques et tous.
Her is my report for 65min, to end of propagations .
From start S8 and after 65min S3.
Old 08-11-2005, 14:49   #15
good results this morning, but there is still the SDC problem
