Old 11-10-2013, 20:08   #1
15445 kHz KTWR from Guam
Yesterday's log was not good at all. Mode C.
Old 11-10-2013, 20:11   #2
FRG-7700 with Active Antenna
Today's transmission produced a little bit of broken sound, but despite the Mode C and 3000 Hz bandwidth it sounded quite good - better than VoN. I was a bit late ad the lod is only 18 minutes long.
Old 12-10-2013, 16:21   #3
f1tay
Reception at Paris
Reception at Paris the 11 and 12 october
Old 12-10-2013, 18:25   #4
About 30% decoded audio this afternoon. They were talking about broadcasing in stereo, but the transmission was in Mode C and with low bitrate. Unfortunately they did not experiment with different modes, I wonder why. One reason for the low decoding was a splattery Saudi 10 kHz down.
Old 05-11-2013, 20:56   #5
Latest round of tests: 2013/11/05
Not much signal here in New Zealand on 15445 kHz. Label decoded, and about 1 second of audio
Old 06-11-2013, 14:55   #6
No signal at all detected or heard in Stockholm this time. The Arab 10 kHz down with a hummy carrier and splattering modulation would have been a problem if the DRM signal had come through.
Old 06-11-2013, 20:33   #7
I didn't receive any signal in Montana either, but I didn't expect it.
Old 07-11-2013, 19:11   #8
Got max. 3.7 dB SNR on 13 MHz from them today, that was all. I won't bother to create a new thread.
Old 08-11-2013, 10:48   #9
No sign at all of the 13760 kHz signal here in NZ.
73 Chris
Old 08-11-2013, 15:36   #10
Even less here today.
