7265 kHz DW-Sines/Wertachtal
  • Filter
  • Time
  • Show
  • df8uo
    • Aug 2003
    • 217
    #31
    Find attached my log from this morning. When Sines is switched off SNR drops significantly
    73, Daniel
    • FritzWue
      • Mar 2003
      • 6269
      #32
      My morning log, reception was better after switching TX around 06:53 UTC.
      The transmitted time service is 53 seconds late here after decoding on a 3GHz P4.
      Is this the accumulated delay? That much?
      EDIT: By the way, saw this too late, peaking 41.0 dB SNR with DRT1!
      • FritzWue
        • Mar 2003
        • 6269
        #33
        One more thing:
        Here are two screenshots of 7265kHz at around 06:30 UTC.
        There is a visible carrier on the signal but no decrease in SNR even when under 20dB. Is this insufficient carrier suppression or what?
        • Andreas
          Junior Member
          • Jul 2005
          • 215
          #34
          Hello Fritz and all other DRM experts!
          Now I'm totally bewildered! On its homepage DW says, that on Tuesday they make use of Sines only? Now when I'm writing this message, text information states, that Wertachtal is on air.
          My both logs cover too short a period round the switching point (which can be clearly heard and seen), to give any further hints. Besides that reception was quite good yesterday. Neither the switing, supposed there was one, nor the shortening of my telescopic antenna rod, which was done WHILE LOGGING in order to fit it under a sunroof had significant influence.
          73, Andreas
          • FritzWue
            • Mar 2003
            • 6269
            #35
            Hi Andreas,
            looks as if this is still an experimental service!
            Maybe the labels are not always correct, and the engineers may perhaps use different settings from what is written in their schedule.
            In my and i.e. Daniel's log we saw them switching the last days around 08:53 UTC, but maybe you in Hamburg are just at the right distance for equally good reception from both transmitters at Wertachtal and Sines.
            • df9rb
              • Jun 2004
              • 484
              #36
              reception improved when Sines started at 7:05.
              • Andreas
                Junior Member
                • Jul 2005
                • 215
                #37
                stable conditions here day by day, and once again but slight differences, when second Tx is switched on and off.
                If it works like this also some 230 km ESE of my QTH they need not be afraid of the IFA
                @Fritz: with 20,96 kbps and P-Stereo they come near to FM sound..........
                73, Andreas
                • CT4RK
                  • May 2004
                  • 150
                  #38
                  DRM some tests
                  Hi all
                  After some time that I didn`t read the forum, I`m back for a short time because I will be on holidays next month.
                  Thanks for your reports. It is normal that there are some perturbations in our transmissions, because since the last 2 weeks we are upgrading the complete DRM system, hardware and software, removing the old encoders and installing the new ones, without stopping the main schedule. It is hard work, but all is runing OK. Please be patient. In the next month, we are able to serve you with DRM signals under the best conditions.
                  73 from CT4RK
                  Carlos Mourato
                  Sines
                  73 from: CT4RK
                  Carlos
                  Sines - Portugal
                  • FritzWue
                    • Mar 2003
                    • 6269
                    #39
                    Re: DRM some tests
                    Seems to be true.
                    Unattended log,
                    skyhigh SNR in the morning before 08:00UTC peaking 41.9dB!
                    • Per
                      • Nov 2002
                      • 1658
                      #40
                      Sept 11
                      The higher frequencies are still affected by bad propagation, so I gave 7 MHz a try.
                      Very good result from DW. Time: 11:09 - 12:00 UTC. CDA: 99%.
                      • mitajohn
                        • Nov 2002
                        • 8439
                        #41
                        A good result for about 70 mins this morning. After this the reception changed to a very bad one.
                        John.
                        • FritzWue
                          • Mar 2003
                          • 6269
                          #42
                          MOBILE RECEPTION
                          Good results from 48712 Gescher to 48135 Muenster:
                          • Bob
                            • Aug 2003
                            • 73
                            #43
                            Interesting results - a clear dropout at 09:00 when I assume Sines stopped transmission. SNR looks lower after 09:00 but decoding rate looks unchanged. Unfortunately my reception was unattended at that time.
                            regards
                            Bob
                            Winradio G303Pro, RCA AR-88D/Sat-Service Schneider LC mixer, plus Wellbrook LA5030 Indoor Loop, longwire antenna
                            • Owdjim
                              Sysop
                              • Jan 2003
                              • 879
                              #44
                              7265 kHz in Wellington
                              Hi All
                              Log for 7265 kHz for today. Journaline data service was decodable for a while too.
                              Marahau, New Zealand, 41° 00' 22"S 173° 00' 33"E, RE68mx
                              My DRM reception page: https://www.owdjim.gen.nz/home/dx-radio/drm/reception/
                              • Digger
                                • Mar 2005
                                • 10097
                                #45
                                11th October
                                This morning the signal here was extremely strong. 100 µV up to 2 mV on the Antenna connector. The SNR was also very good . A short break at 09 UTC was noted.
                                73
