RTL on 1440 kHz
  • Filter
  • Time
  • Show
  • Baldo34
    • Apr 2003
    • 121
    RTL on 1440 kHz
    RTL in DRM now on 1440 kHz.
    See screenshot.
    73, Klaus
    Equipment: Winradio WR-G303i
    DX-10 active antenna
    http://www.drm-dx.de
  • Per
    • Nov 2002
    • 1687
    #2
    Quite amazing, I get 6 dB SNR here in Stockholm at 12:30 local time. (11:30 UTC). Both Sync and Data LEDs are active. The RFI Tx in Sankt-Petersburg is interfering with RTL.
    • Baldo34
      • Apr 2003
      • 121
      #3
      at the moment only S 7 near Kassel, but SNR 21 dB and full audio. Very good!
      73, Klaus
      • dk8cb
        • Mar 2004
        • 2748
        #4
        30% audio in Munich
        even in Munich at bright midday sunlight, about 30% audio may be decoded.
        • LX1RE
          • Dec 2002
          • 17
          #5
          Starting from today, DRM trial transmissions from Marnach on 1440kHz between 0:00 and 3:50 UTC on a regular base.
          Eugène
          • radiomann
            • Jun 2003
            • 297
            #6
            Originally posted by LX1RE
            Eugène
            Hi Eugene,
            any idea when you will broadcast earlier in the evening on 1440? Or can't you do that with CRI on 1440 from 7pm?
            Regards
            Paul
            • DRM-Fan
              • Jun 2003
              • 209
              #7
              Is this transmission going to be any good for South UK at least at night time ?
              DRM radio. New yahoo group for all owners of DRM radios - Please join at :- http://groups.yahoo.com/group/alldrmradio/
              • radiomann
                • Jun 2003
                • 297
                #8
                I was always told the further North you are the better the signal would be on 1440, I lived in the North-West for 27 years and have lived here in the South- East for the past 8 years or so and not noticed any differance in reception, so hopefully we should get a decent reception where we are, fingurs crossed. Mind you we don't even know where they are aiming the signal, I would presume where they always have aimed it?
                Paul
                • lx1nw
                  Michel Asorne
                  • Dec 2002
                  • 77
                  #9
                  Antenna pattern should be ok for UK. DRM Transmission mode and bitrate might be a bit too high for skywave propagation, I hope reports will give us a clue on this matter.
                  73 Michel
                  • radiomann
                    • Jun 2003
                    • 297
                    #10
                    Looking forward to it Michel, no real MW/DRM tests anywhere, and as you have probably noticed I rate RTL highly and want you to suceed with DRM, but I do get frustrated at times.
                    Any info on what will be broadcast tonight?
                    Paul
                    73 Michel
                    • carknue
                      • Dec 2002
                      • 1321
                      #11
                      A good copy of a good old Mike Hollis show would be nice.
                      • radiomann
                        • Jun 2003
                        • 297
                        #12
                        Now that would be worth staying up for, I think they should use the Musicjam shows, be a good test I think, as for poor Mike he is stuck on Saga here in the UK
                        • radiomann
                          • Jun 2003
                          • 297
                          #13
                          Oh must say 1440 is booming in here as usual, with the usual fades
                          Will be interesting............
                          • dk8cb
                            • Mar 2004
                            • 2748
                            #14
                            SNR is around 20 dB at the moment here in Munich but there is no audio at all.
                            Strong signal.
                            Edit 00:09 UTC: SNR has now risen to >23 dB at times. Still no audio.
                            • radiomann
                              • Jun 2003
                              • 297
                              #15
                              SNR 15-18 quite poor but like you no audio???????
