9770 kHz VT Digital from Rampisham
  • Filter
  • Time
  • Show
  • simone
    • Jan 2003
    • 10144
    Good results as usual.
    • Sixten
      • Jun 2005
      • 3513
      Aug 25
      Log today , signal was very strong S9+30db only slow QSB S9+10/S9+30db.
      But so start tundrstorm after 30min. Very fast switch off.
      • simone
        • Jan 2003
        • 10144
        A perfect start of the tranmission today with announcements, also Journaline was working again, thanks !
        Unfortunately bad results in the car from 15:22 due to thunderstorms
        • simone
          • Jan 2003
          • 10144
          Great results today.
          • Sixten
            • Jun 2005
            • 3513
            Sep. 1
            Great results today strong signal only slow QSB. Problem from start no sound.
            • simone
              • Jan 2003
              • 10144
              Good results apart from the last minutes.
              But no audio/very low audio level at the beginning, then playing a loop with music later regular programming continued, also again a problem with Journaline
              • Digger
                • Mar 2005
                • 10097
                Hm, here I "enjoyed" Radio China AM around 1630 UT in Chinese with S3 on the meter, which was 20 dB over the DRM.
                • simone
                  • Jan 2003
                  • 10144
                  special transmission on Sunday, Sept 3rd
                  There will be a special VTdigital transmission tomorrow (Sunday, Sept 3rd) for RTE, times and frequencies are:
                  1300-1400 9795 kHz,
                  1400-1700 9770 kHz
                  Please post results here.
                  • simone
                    • Jan 2003
                    • 10144
                    No audio problems and great results today
                    • mitajohn
                      • Nov 2002
                      • 8424
                      A signal up to 40dBuV with continual carrier interuptions and QRM at the right edge of DRM spectrum gave the attached result. The sound from the game was good.
                      John.
                      • Digger
                        • Mar 2005
                        • 10097
                        The 9770 was plagued with interruptions in the beginning. Here is the (unattended) log:
                        • simone
                          • Jan 2003
                          • 10144
                          RTE 3rd Sept
                          Strong signal but many interruptions in transmission, later also longer breaks on 9770 kHz, no signal after 1524. Interesting to see Mode A being used which worked great with a short IR, also better audio quality and wider audio bandwidth than on the Asian broadcasters on Fridays (which are probably limited by the audio feed).
                          Good reception also with the Roberts MP40 with the built-in antenna indoors.
                          • mitajohn
                            • Nov 2002
                            • 8424
                            Impossible decoding due to heavy interference, although the signal was rather strong.
                            John.
                            • simone
                              • Jan 2003
                              • 10144
                              Started quite good in the first hour, bad conditions later with a weak and instable signal, also some interference, no decoding in the last hour
                              • Sixten
                                • Jun 2005
                                • 3513
                                Sep. 15
                                Hi.
                                Log today.strong and stabile signal ,last 51min.
