Old 28-01-2019, 10:10   #16
@Marcel:
Nice audio from RM&G. Merci!
Old 28-01-2019, 11:55   #17
MARCEL
Hallo Terje,
Kein problem war sehr gut hier, aber du bist Ja weit weck in Japan.
Grüss zu dir.
DRM:
Mixer Platine MF9 Mhz with Dream
Antenna:
Mantova Turbo 5/8 wave for 27 mhz
Long Wire 80 meter
MARCEL is offline   Reply With Quote
Old 28-01-2019, 20:24   #18
Originally Posted by drmdab
I wonder if this actually could be the first (public) DRM transmission from Uzbekistan ever?!
I think it probably was, I've never heard of any from there before. Spaceline in Bulgaria have done a few, but I don't think any of the other relay services have.
It would be interesting to know just which countries do have DRM capable transmitters.
Modified NRD-525G with
Radiokit DRM Decoder Board,
SDRplay RSP-1A, SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
https://www.ndblist.info
Old 29-01-2019, 21:05   #19
In the meantime, I found this. So it seems like it just was the first official DRM transmission from Uzbekistan.
Old 20-02-2019, 20:06   #20
And another DRM transmission next Sunday:
Radio. Menschen & Geschichten ( = Radio. People & Stories) will be on air...
0900-1000 UTC online live streaming www.radiomenschenundgeschichten.de
1800-1900 UTC in AM on 5830 kHz and
1930-2030 UTC in DRM on 5830 kHz
Old 22-02-2019, 13:58   #21
Thanks a lot for the info, hopefully I will have better luck with receiving it this time.
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
Old 24-02-2019, 18:48   #22
No problems hearing it here this time, a lovely big signal here with 22.0db SNR and nice clear audio.
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
Old 24-02-2019, 19:18   #23
AlexDRM
Very good reception of Radio. Menschen und Geschichten on 5830 kHz!
DRM label = Radio Uzbekistan
RMG-13755kHz_PNG
AlexDRM is offline   Reply With Quote
Old 24-02-2019, 19:30   #24
A very good signal most of the way through, averaging 20 - 22db SNR up to the last 15 minutes, when the signal strength started to drop a bit and was around 16db SNR by the end. I did get a few momentary drop outs then, but I wasn't noticing any changes on the receiver's carrier strength, so possibly some local QRM may have been causing this. The audio sounded very nice though, which is not always the case with some DRM stations! :-)
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
Old 24-02-2019, 19:50   #25
Feb_24
A result for 26mins. Mediocre RF signal, but low SNR, as a result too much dropouts. Good audio, up to ~10kHz, when decoded. 61.9% CDA / 19.4dB max SNR.
(On the first plot are included: the screen-shot of the Label as well as the DRM mode)
Old 24-02-2019, 19:52   #26
DRM Hdn
DRM Hdn's Avatar
Radio, Menschen & Geschichten in DRM 27th January 2019
A very good reception result this evening! Thanks to all makers for this 1h top DRM Radio enjoyment.
Regards from Elbflorenz,Saxony
DRM Hdn is offline   Reply With Quote
Old 25-02-2019, 19:51   #27
MARCEL
Yes very good reception SNR 28 to 29 db audio 100 % :
https://nsa40.casimages.com/img/2019...5453321334.jpg
DRM:
Antenna:
Long Wire 80 meter
Old 03-04-2019, 15:39   #28
Hi All,
Alan Pennington just relayed the following info via the bdxc-news mailing list, one to look out for:
"It is planned to air a DRM Test tonite from Armenia on 7595 kHz at 1700-1800 UTC.
(Christian Milling - Shortwave Service - on WRTH - World Radio TV Handbook Facebook 3-April)"
This may not be the right section for it, but if I make it a new post it probably won't get out to enough members in time, and it's probably for RMG
anyway!:-)
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
Old 03-04-2019, 17:03   #29
It's a good signal here and showing 'Noratus' on the ID panel, but the audio sounds a bit overdriven.
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
