Go Back   DRM Software Radio Forums > DRM Software Radio - User Forums > Links
Old 07-06-2010, 16:06   #91
Originally Posted by dadalbinder
there is no possibilty to send paramter-files of SPARK by the appendix of the forum.
The only way at the moment seems to be, to send them by EMail.
Wolfgang Hartmann, NÜrnberg
Hi Wolfgang,
you can attach the config file as a .zip or rename it as .txt, no problem!
Old 07-06-2010, 20:16   #92
PP5AZF-Ataliba
Why should you see a message "in the FFT library found" when installing 2.5.0 SPARK?
Qual o motivo para aparecer uma mensagem "no FFT library found" durante a instalação do SPARk 2.5.0?
since today there is a new test-version of Michael Feilen of SPARK. It is named 2.5.0.
It has a lot of features, which are suitable to exchange the parameters for modulation for different modes.
I made a fist test file and it did work instantly with my parameters in DRM+ mode.
The version is limited to a running time of 30 minutes. Enough, to produce WAV-files of some hundred mega.
Thank You for this common version. Now all experimenters are able, to work on the same program and discuss fixed paramteres.
Best regards to Michael Feilen and the experimentators.
Wolfgang Hartmann, Nürnberg
Plataforma Brasileira do Digital Radio Mondiale
www.drm-brasil.org
Amostras de áudio de algumas rádios DRM:
www.zandomenego.com/ataliba
PP5AZF-Ataliba is offline   Reply With Quote
Old 08-06-2010, 18:30   #93
dadalbinder
FFT while downloading
Hi Ataliba
I think the translation of Your original text seems for me wrongly translated, if I read Your original text.
You see: "no FFT library found" and not the controversial info as in english language.
I am able to understand a little bit italian language but not portugese or spanish language.
If it is as You wrote in Your original message, You should ask Michael Feilen at his homepage for help
Sorry
dadalbinder is offline   Reply With Quote
Old 08-06-2010, 18:56   #94
maxpower
Hello Ataliba!
I didn't get the spark version 2.5. until now. :-( But normally there is a fft.dll inside the spark directory folder. Is it missing in your installation?
73, Stephan
"Pappradio" 2 SDR / Himalaya 2009, near Leer/Ostfriesland (Web remote-controlled) 15m Long-Wire / Active Deltaloop, Asus Xonar 192 kHz / Realtek HD Soundcard, Atom 330 ITX Mainboard, rural area; 53'10N, 7'27E;
maxpower is offline   Reply With Quote
Old 08-06-2010, 20:11   #95
Originally Posted by maxpower
... But normally there is a fft.dll inside the spark directory folder. Is it missing in your installation?
73, Stephan
Hi Ataliba,
Spark is using the FFT library called Kiss FFT, the package contains the required dll "kissfft.dll", did you already check you have the correct Java version installed?
Old 08-06-2010, 20:40   #96
maxpower
So it seems that this has been changed from < 1.7 to the newer versions?!
I've looked into all versions that I have (1.3, 1.70, 1.71) and they all used a fft library fft.dll and no kissfft.dll on my - with java installed - systems?!
Stephan
Old 08-06-2010, 22:49   #97
PP5AZF-Ataliba
Microsoft Windows XP
Professional
Version 2002
Service Pack 3
JAVA version 6 update 20 (build 1.6.0_20-b02
Teste sua versão JAVA VIRTUAL MACHINE:
http://java.com/pt_BR/download/help/testvm.xml
Hi Ataliba,
www.drm-brasil.org
Old 09-06-2010, 05:26   #98
Hi Ataliba,
try and delete fft.dll, you do not need it there.
Old 12-06-2010, 08:26   #99
dadalbinder
SPARK what now?
thanks to Michael Feilen we have now a common and nice version 2.5.0.
New Tops:
1. Ideal and experienced parameters for all modes?
2. Hardware solutions to build an experimental mixer?
Would it be meaningful to extense the discussion?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
