-   Reception Results - Archive (http://www.drmrx.org/forum/forumdisplay.php?f=16)
-   -   9730 kHz RTL test (http://www.drmrx.org/forum/showthread.php?t=1587)
jbriggs 17-12-2006 22:59
9730 kHz RTL test
I would be grateful for comments on the following planned for tomorrow, Monday December 18th for 1 day only:
9730 kHz from Austria 1100-1230 UTC.
50 kW DRM
Antenna HR 4/3/0.6
295 degrees (Benelux)
Any comments on audio quality field-strength etc much appreciated. Thanks, James
simone 18-12-2006 13:00
2 Attachment(s)
Hi James,
started quite good, only a weak signal after the first 35 minutes for the rest of the transmission, no problems with mode A, audio quality was OK considering the bitrate.
simone 18-12-2006 13:01
1 Attachment(s)
... also no problems with the MP40 at the beginning.
LX1RE 18-12-2006 14:10
Reception BelRTL Morphy Richards
Reception with Morphy Richards in my home in Luxembourg, Average low fieldstrength, some dropouts, worse after 12:10 UTC with SNR's below 9dB. Rather bad sound quality, audio input level seems to be not correct.
73's
Eugene LX1RE
carknue 18-12-2006 15:25
1 Attachment(s)
Hi James,
same results like Simone. After the first 30 min, no reception was possible again. See graph with fieldstrength. Sound quality was not the best.
simone 18-12-2006 20:08
1 Attachment(s)
Here is a typical example what the audio spectrum looked like and a recording
from music and speech.
