-   -   Voice of Nigeria 15120 kHz from Abuja (http://www.drmrx.org/forum/showthread.php?t=2390)
mitajohn 26-10-2013 20:12
Oct_26
2 Attachment(s)
An unattended log.
AF4MP 27-10-2013 11:46
Voice of Nigeria 15120 kHz reception near Atlanta, Georgia, USA
1 Attachment(s)
Yesterday afternoon's reception - only 0.3% audio decoded.
mitajohn 27-10-2013 20:43
Oct-27
2 Attachment(s)
A perfect log for 1 hour.
tpreitzel 28-10-2013 18:23
Thankfully, transmissions from Cariari have been suspended so REE's broadcast to SA during the winter on 15115 kHz has been removed along with the interference to VON's broadcast. Now, I might have a decent chance of decoding VON as the spectrum looks pretty clean in NA. Currently, I'm receiving a fairly clean signal from VON.
tpreitzel 29-10-2013 00:09
1 Attachment(s)
Ambient Conditions: Unknown ... PC off ( 0 dB loss )
Due to the absence of interference of Cariari's former broadcast to SA on 15115 kHz, I now stand a chance of decoding VON's broadcast ...
Although not good, this log is my personal best thus far. I expect much better in the future.
AF4MP 29-10-2013 11:20
1 Attachment(s)
Yesterday afternoon's reception - 3.53% audio decoded.
mitajohn 29-10-2013 19:14
Oct_29
2 Attachment(s)
A perfect result for 42 mins.
tpreitzel 29-10-2013 23:13
1 Attachment(s)
Ambient Conditions: Unknown as I wasn't planning on posting this log. PC on ( 2 dB loss)
Due to minimal strength of the signal, I normally remove power to my PC when receiving VON, but I was distracted by other events.
AF4MP 30-10-2013 12:04
1 Attachment(s)
Yesterday afternoon's reception - 1.74% audio decoded.
AF4MP 31-10-2013 12:54
1 Attachment(s)
Yesterday afternoon's reception - 38.35% audio decoded.
tpreitzel 31-10-2013 19:28
1 Attachment(s)
Ambient Conditions: 54 F @ surface, RH 47 %, partly overcast, average noise, PC off but I left mesh node ON ( 8 dB loss )
Incredibly, I left my mesh node powered which absolutely killed the signal ... I removed power to the mesh node at ~ 1951Z. ;) Without the mesh node running, the SNR would have hit 13 dB at 1925Z.
AF4MP 01-11-2013 11:13
1 Attachment(s)
Yesterday afternoon's reception - 25.16% audio decoded.
tpreitzel 01-11-2013 19:21
1 Attachment(s)
Ambient Conditions: 51 F @ surface, RH 41 %, overcast, average noise, PC off ( 0 dB loss )
AF4MP 02-11-2013 11:30
1 Attachment(s)
Yesterday afternoon's reception - 8.14% audio decoded.
tpreitzel 02-11-2013 19:29
1 Attachment(s)
Ambient Conditions: 51 F @ surface, RH 50 %, clear, average noise, PC off ( 0 dB loss )
Although most of the decoded audio was madly broken due to borderline signal-to-noise ratio (SNR), I was pleased to actually hear some significant content for the first time from VON. Tentatively, most of the variation in loudness appears due to production, not propagation, but I need to hear more to accurately judge. Also, on my Newstar DR111, a listener needs a SNR of 10 dB for unbroken, clean reception from VON. With a SNR of 9 dB, a listener will hear broken audio. So for the majority of Americans, you basically have two choices for DRM reception in the USA currently, RNZI and VON. This situation will likely improve significantly by next year.
A tip: If a listener owns Newstar's DR111, record the program and replay the program back on a version of DReaM 2.1+ with the option, --permissive 1. The listener will find the playback is more clearly understood (more fully decoded?) on DReaM than the DR111.
AF4MP 03-11-2013 12:34
1 Attachment(s)
Yesterday afternoon's reception - 16.32% audio decoded.
Digger 04-11-2013 07:14
DR111 in the house with whip antenna
1 Attachment(s)
It started out promising, but the propagation deteriorated quickly.
AF4MP 04-11-2013 14:22
1 Attachment(s)
Yesterday afternoon's reception - 25.57% audio decoded.
mitajohn 04-11-2013 19:08
Nov_04
2 Attachment(s)
An unattended log.
tpreitzel 04-11-2013 19:23
1 Attachment(s)
Ambient Conditions: 34 F @ surface, RH 69 %, overcast, average noise, PC off ( 0 dB loss )
I only recorded the last 20 minutes of the broadcast. Although the carrier was fairly strong, it wasn't modulated so the listener only heard silence.
AF4MP 05-11-2013 11:34
1 Attachment(s)
Yesterday afternoon's reception.
tpreitzel 05-11-2013 19:14
1 Attachment(s)
Ambient Conditions: 35 F @ surface, RH 66 %, partly overcast, average noise, PC off ( 0 dB loss )
AF4MP 06-11-2013 13:33
1 Attachment(s)
tpreitzel 06-11-2013 20:17
1 Attachment(s)
Ambient Conditions: 48 F @ surface, RH 37 %, overcast, average noise, PC off ( 0 dB loss )
Due to my absence, I needed to power my DR111 from AC today. Unfortunately, when I attempted to save the file, the DR111 dumped portions of the log AND the recording so I was left with this partial log. <sigh> I seriously need to find a replacement power supply.
AF4MP 07-11-2013 13:42
1 Attachment(s)
Yesterday afternoon's reception - 17.48% audio decoded.
tpreitzel 08-11-2013 00:23
1 Attachment(s)
Ambient Conditions: Unknown as I wasn't planning on posting this log. PC off ( 0 dB loss )
As I mentioned in a previous log, a listener using Newstar's DR111 needs a minimal SNR of 10 dB to decode audio from VON which is clearly shown in this log at 1943Z.
mitajohn 08-11-2013 19:08
Nov_08
2 Attachment(s)
An almost perfect result for 32 mins.
tpreitzel 08-11-2013 19:27
1 Attachment(s)
Ambient Conditions: 50 F @ surface, RH 33 %, overcast, HIGH noise, PC off ( 0 dB loss )
I'm unsure whether this log is a consequence of a X-flare about 12 hours earlier as the signal is normally so weak at my location anyway.
AF4MP 09-11-2013 11:16
1 Attachment(s)
Yesterday afternoon's reception - 40.81% audio decoded.
AF4MP 10-11-2013 12:08
1 Attachment(s)
AF4MP 11-11-2013 15:14
1 Attachment(s)
Yesterday afternoon's reception - 47.69% audio decoded.
Digger 11-11-2013 15:18
I listened last night, but there is no signal at all now up here.
tpreitzel 11-11-2013 18:45
I received a SNR of ~ 2 dB only at the tail end of the broadcast so the problem is probably due to auroral effects at our northern locations.
mitajohn 11-11-2013 19:09
Nov_11
2 Attachment(s)
Weak signal tonight, but good results. After 19H35 a nearby storm started with a lot of lightning which affected the decoding.
Digger 11-11-2013 19:24
Mystery
1 Attachment(s)
The comment regarding "no signal at all" was based on reception with the DR111. In the FRG-7700 I could hear a signal, and with Dream I got the enclosed log. But the propagation gave up on me around 1900 (the backup battery is flat, so the time might be a little bit inaccurate and it was't the Dual Core Pentium either...). So the first 19 minutes were perfect with 99.97% CDA.
tpreitzel 11-11-2013 19:34
With a quite sensitive receiver and good antenna, I'd expect reception of VON in northern Europe to be quite strong under normal atmospheric conditions since the azimuth is toward Sweden, definitely greater than DReaM receiving a SNR of 15 dB. Stockholm is about 3500 miles from Abuja. Given the apparently poor atmospheric conditions, a SNR of 15 dB was quite good.
For example,
http://drmrx.org/forum/showpost.php?...&postcount=332
Digger 12-11-2013 08:05
Off topic: VoN and DR111
The peculiar thing last night and the night before was that the DR111 in "expert mode" did not show anything but zero dB SNR in the display... but the FRG-7700 with Dream was 100% OK. I'll check again tonight. I need to find out the reason why the DR111 would not react to the VoN signal.
mitajohn 12-11-2013 19:08
Nov_12
2 Attachment(s)
An almost perfect result.
Digger 12-11-2013 20:43
Not good at all this evening. Again there was no reaction at all from the DR111 and the signal quality was really bad, so I did not even bother logging with Dream and FRG-7700.
By the way, I couldn't find VoN on 15120 kHz in the B13all00.TXT. If they are running 100 kW DRM and if they use something like a 4/2/0.5 antenna at 360 AZ, then we would be getting a very strong RF signal here in Scandinavia. But tonight the propagation was dreadful.
AF4MP 13-11-2013 17:16
1 Attachment(s)
Yesterday afternoon's reception - 50.68% audio decoded.
