-   -   9950 kHz AIR India Tests to Europe from Khampur (http://www.drmrx.org/forum/showthread.php?t=1641)
Digger 31-03-2015 21:23
1 Attachment(s)
Back to the old label.
mitajohn 01-04-2015 19:22
April_01
2 Attachment(s)
Yes, Terje, back to the old label and BR. I run a log for 81 mins until the signal dropped and decoding turned bad.
Digger 01-04-2015 21:11
1 Attachment(s)
I started my log at 1750 tonight and there were a couple of periods with weaker signals. On the whole I got 96.5% decoded (unattended) audio. The log is 190 minutes long.
@John
After you quit logging, did the signal improve later or did it just only go downhill?
Digger 02-04-2015 20:32
1 Attachment(s)
Not so good this evening. Only 78% decoded hum, errr, audio.
mitajohn 02-04-2015 20:39
April_02
2 Attachment(s)
@ Terje
I have no idea what happened after I stopped of logging because I turned off the radio.
Here's a result for 155 mins. No good conditions, the log speaks for itself.
Digger 03-04-2015 20:14
1 Attachment(s)
Perfect for more than two hours, but then the signal dropped dramatically and I stopped the log.
Digger 04-04-2015 21:30
1 Attachment(s)
161 minutes and 97.4% decoded "audio". Hum, nothing, low levels, distorted. Hmmm...
Digger 05-04-2015 20:06
1 Attachment(s)
113 minutes and 99.72% decoded "audio". Hum, distorted. Hmmm..
Digger 06-04-2015 21:22
Sounds of silence...
1 Attachment(s)
No distortion or hum tonight. (No sound at all mostly...) 99.65% decoded nothing. Max SNR was 28.28 dB. It started out as Russian Service which later on switched to GOS IV.
Digger 07-04-2015 21:14
1 Attachment(s)
A 147 minutes long unattended log. 94% CDA and max. 29.13 dB SNR.
mitajohn 07-04-2015 21:42
April_07
2 Attachment(s)
An unattended log for 188 mins, ~76% CDA.
Digger 09-04-2015 10:26
1 Attachment(s)
95% decoded "audio" last night. The audio was mostly hum with superimposed, low level - audio. I wonder what they're up to? Is there nobody around who can check what they are transmitting?
Digger 10-04-2015 21:11
1 Attachment(s)
Almost 99% decoded audio tonight, and the audio was better than last night. The SNR peaked at 29.42 dB.
Digger 13-04-2015 21:26
1 Attachment(s)
Almost 99% decoded audio tonight, and the audio was pathetic, mostly. The SNR peaked at 28.6 dB.
Digger 15-04-2015 05:29
1 Attachment(s)
97% decoded audio that consisted of hum, noise, fizz and buzz plus some distorted audio in between. :rolleyes:
