-   -   RNZI 9870 kHz (http://www.drmrx.org/forum/showthread.php?t=1528)
Sixten 09-11-2006 14:27
Nov.09
1 Attachment(s)
I tune in on this new freq , 1010UTC , so log only 49min.
Transmission stop 1100UTC.
Very strong and stabile signal S9+10db . And total clear freq.
After 1100 UTC I move to 9870 and now was RNZI on this freq.
But I have now very strong AM on 9865 and 9875 .
zfyoung 10-11-2006 05:38
Nov. 9th
1 Attachment(s)
Strong signal (S9) here in South East China,but long IR. Sorry for the period between 1150 UTC to 1155 UTC as the two verticle line has shown. During that period I used the magnetic electric oven (1.8 kW) to boil soming drinking water and that oven is less than 5 meters away from my receiver antennas!
Starting from 1200 UTC there is adjacent channel interfernce as usual but conditions are in my favor tonight compared with last night.
Sixten 10-11-2006 09:32
Nov.10
2 Attachment(s)
Very bad propagation for strong AURORA, Level 9.
See picture from NOAA18.
Janucha 11-11-2006 11:09
1 Attachment(s)
It was amazing that I received station the farthest as possible on earth from my home- 17550 km. Today is much stronger.
Sixten 11-11-2006 12:55
Nov.11
1 Attachment(s)
Hi.
Very good propagation on 9870Khz today.Log 50min.
Sixten 13-11-2006 14:03
Nov.13
1 Attachment(s)
Fantastic propagation from New Zealand on this band.
Log 57min. CDA 99% ok. Stop 1158UTC for AM station start +5Khz .
Digger 16-11-2006 12:20
1 Attachment(s)
The same as usual here. Ups and downs.
Sixten 16-11-2006 13:20
Nov.16
1 Attachment(s)
Good signal strength today also, but splatter from AM on 9865 and 9875Khz after 1200UTC.
Sixten 20-11-2006 11:10
Nov.20
1 Attachment(s)
:confused:
f1tay 20-11-2006 12:10
1 Attachment(s)
Reception at Paris.
Daniel
Digger 20-11-2006 12:43
1 Attachment(s)
The signal rose slowly and from about 1125 UTC the decoded audio was almost perfect until QRT. I used two receivers sharing the Long Wire Antenna.
The adjacent channels were very clean today. Some AM 5 kHz up, but the weak signal caused no harm.
Sixten 31-10-2007 13:06
31 Oct.
1 Attachment(s)
Strong signal from RNZI but sorry for strong AM also on 9870.CDA 80% ok from log 34min.
Sixten 02-11-2007 09:51
02 Nov.
1 Attachment(s)
Very good signal from RNZI this morning . Only AM problem start 1000 UTC . Log 159min CDA 97%ok
FritzWue 02-11-2007 12:16
2 Attachment(s)
Wintertime is RNZI time here... :)
Did some tests with my two inverted L antennas at start.
The northeastern L as antenna and the northwestern L grounded turned out to be the best combination.
At 12:00 UTC AM interference from both sides +/-5 kHz started.
Good audio with that low bitrate.
Ant-SWL 02-11-2007 18:18
RNZI 9870 KHz
1 Attachment(s)
Semi-attended log:
When log starts RNZI and an AM-Station used same channel.
The RNZI-Signal was not so weak at Log-beginning. Signal rising up 1200 UTC.
Later here also two AM-Signals +- 5 KHz.
